Post-Synthesis Simulation for a block design containing AXI VIP
I know this is a silly doubt, and if someone could confirm this, my mind will be at peace
Page 38 of AXI Verification IP (https://www.xilinx.com/support/documentation/ip_documentation/axi_vip/v1_0/pg267-axi-vip.pdf) says
Does this mean it is not possible to perform post-synthesis (and by def. post-implementation) simulation for a block design containing a custom AXI IP (having master AXI interface) and AXI VIP IP (having AXI Slave VIP) ?
I'm getting this error when I run post-synthesis functional simulation
ERROR: [VRFC 10-93] IF is not declared under prefix inst
Whereas Behavioral Simulation works without any problem.
The reason I asked is, I wanted to check if my custom IP is generating correct AXI signals even after I synthesize and implement.
Is there any way I can quell such concerns ?
(I didn't get any unusual warnings such as sequential element dropped etc. when I synthesized my custom IP in IP Packager)
Maybe I'm answering my own questions myself, but I'd like to know if any of above assumptions I've made are incorrect.
EDIT 1:
In case behavioral simulation is sufficient to check if AXI master signals (in custom IP) I'm generating are correct, then can I assume that I won't face any problems (related to AXI) when I include this IP in a larger design ?
EDIT 2:
This link  https://forums.xilinx.com/t5/Simulation-and-Verification/Using-AXI-BFM-in-post-synthesis-implementation-simulations/td-p/783671 says that AXI VIP (and BFM) cannot be used for post synthesis and post implementation.
Thank You
Jagannath
