Visitor leepoult
Post netlist simulation for FPGA debugging; how can I pre-load a file into FPGA block memory?
I'm doing post-netlist simulation with place&routed netlist and SDF from Vivado.
I use VCS for simulator and I can successfully compiled my netlist and SDF.
But I got an error when I trying to upload a MIF(or axf, it is a firmware) into the block ram.
Actually I've done this process in RTL level simulation.
I got a CPU core in my design and I need to upload a compiled firmware file into the code area block ram.
I don't know how can I put it in... I've found "uploadmem, data2mem" methodolgy on the web.
But it seems not for the simulation.
Anyone know about this?
Re: Post netlist simulation for FPGA debugging; how can I pre-load a file into FPGA block memory?
Hi @leepoult,
Have a look at the following post that may help.
https://forums.xilinx.com/t5/Simulation-and-Verification/Initializing-block-RAM-for-simulation/m-p/857776#M22260
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Visitor leepoult
Above link, that may helpful if I use RTL level sim.
Actually I've already use "readmemh" when I simulate in RTL level.
But it's impossible with post-netlist because I got only one big huge netlist file and there are splited block memories, LUT and other basic components of FPGA.
For example, I made one 128x64 spsram memory using block memory gen. but I got lots of distributed (splited) BRAMs and LUTs and others on my netlist.
I know how to insert pre-compiled code into the bit file.
But I don't know how can I put it into the post-routed-netlist.
