xubintan
Print output into text file using Xilinx Isim
Hi, Dear All,
Since i need to use some output signals which have a huge number of values, so i wonder if there are any method for me to save the value appeared on the waveform into a excel like data file or text file?
Thank you very much!
vuppala
I dont think isim have an option to output values to a txt file.
But you can print the waveform using File -> Print Preview Option. See this user guide for more information: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/plugin_ism.pdf
Vinay
