Problem with -93_mode in Vivado 2016.3 simulator
So I discovered that in 2016.3, the Vivado simulator uses the VHDL 2008 library versions for all files, even those that are not of type 2008. This means that if any VHDL files are incompatible with 2008 (as was my case) that simulation fails with compile errors. A proposed workaround is to use the -93_mode flag which forces the entire design to VHDL 93. (see this thread)
The trouble is that when I add the -93_mode to xsim.compile.xvhdl.more_options, the simulator fails with error VRFC 10-113 and reports that "sim_1/behav/xsim.dir/osc/osc_tb.vdb needs to be re-saved since std.standard changed". This same project simulates fine in 2016.2 (without -93_mode, which is unsupported). I have created a new project in addition to upgrading the existing project, both with the same result. All VHDL files are of type VHDL (not VHDL 2008), and I tried 'set_param project.enableVHDL2008 0' to no avail. I found a couple of threads referencing the same error (here and here), but neither seems to solve my problem.
I would like to be able to use 2016.3 as it provides improvements that are helpful to me, but I can't if the simulator will not work. Help!
Re: Problem with -93_mode in Vivado 2016.3 simulator
I have confirmed this problem also exists in the 2016.4 simulator. Both versions are installed on Ubuntu 16.04.1 LTS. Creating a new project with a single trivial file, adding the -93_mode flag to xsim.compile.xvhdl.more_options, and then trying to simulate results in an error.
Can someone from Xilinx please provide assistance?
Here are the test file contents and log.
library ieee;
use ieee.std_logic_1164.all;
entity test is
 port (
   x : out  std_logic
end entity test;
architecture std of test is
begin
  x <= '1';
end architecture std;
launch_simulation
INFO: [SIM-utils-51] Simulation object is 'sim_1'
INFO: [USF-XSim-37] Inspecting design source files for 'test' in fileset 'sim_1'...
INFO: [USF-XSim-97] Finding global include files...
INFO: [USF-XSim-98] Fetching design files from 'sim_1'...
INFO: [USF-XSim-2] XSim::Compile design
INFO: [USF-XSim-61] Executing 'COMPILE and ANALYZE' step in '/home/btrotter/workspace/vivado_test/2016.3/test.sim/sim_1/behav'
xvhdl -m64 --relax -prj test_vhdl.prj -93_mode
INFO: [VRFC 10-163] Analyzing VHDL file "/home/btrotter/workspace/vivado_test/2016.3/test.vhd" into library xil_defaultlib
INFO: [VRFC 10-307] analyzing entity test
INFO: [USF-XSim-69] 'compile' step finished in '1' seconds
INFO: [USF-XSim-3] XSim::Elaborate design
INFO: [USF-XSim-61] Executing 'ELABORATE' step in '/home/btrotter/workspace/vivado_test/2016.3/test.sim/sim_1/behav'
Vivado Simulator 2016.3
Copyright 1986-1999, 2001-2016 Xilinx, Inc. All Rights Reserved.
Running: /opt/Xilinx/Vivado/2016.3/bin/unwrapped/lnx64.o/xelab -wto e81b1fcb5f5b4e5a98436ddfbd9574d9 --debug typical --relax --mt 8 -L xil_defaultlib -L secureip --snapshot test_behav xil_defaultlib.test -log elaborate.log
Using 8 slave threads.
ERROR: [VRFC 10-113] /home/btrotter/workspace/vivado_test/2016.3/test.sim/sim_1/behav/xsim.dir/xil_defaultlib/test.vdb needs to be re-saved since std.standard changed
ERROR: [VRFC 10-147] xil_defaultlib.test failed to restore
ERROR: [XSIM 43-3225] Cannot find design unit xil_defaultlib.test in library work located at xsim.dir/work.
INFO: [USF-XSim-69] 'elaborate' step finished in '0' seconds
INFO: [USF-XSim-99] Step results log file:'/home/btrotter/workspace/vivado_test/2016.3/test.sim/sim_1/behav/elaborate.log'
ERROR: [USF-XSim-62] 'elaborate' step failed with error(s). Please check the Tcl console output or '/home/btrotter/workspace/vivado_test/2016.3/test.sim/sim_1/behav/elaborate.log' file for more information.
ERROR: [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
-93_mode should be passed to both xvhdl and xelab.
Please try to add -93_mode in xsim.elaborate.xelab.more_options field.
@graces: adding -93_mode to xsim.elaborate.xelab.more_options solved the original problem.
However, now I am trying to simulate a design using unisim.vcomponents and I get the following error:
ERROR: [VRFC 10-113] /opt/Xilinx/Vivado/2016.4/data/xsim/vhdl/unisim/unisim.vdbl needs to be re-saved since std.standard changed
How do I simulate using -93_mode and unisim? Please advise.
@brian.trotter
This could be because UNISIMS are already compiled with VHDL 2008.
Can you share a simple testcase to try at our end?
Sravanthi
@svanapar, that is my suspicion. So the question is, is there a workaround? Per your request, here is a simple test case. Please advise.
library ieee;
library unisim;
use unisim.vcomponents.all;
entity unisim_test is
  port (
    O : out std_logic;
    I : in  std_logic
end entity unisim_test;
architecture std of unisim_test is
begin
  INST : OBUF
  port map (
    O => O,
    I => I
xvhdl -m64 --relax -prj unisim_test_vhdl.prj -93_mode
@brian.trotter
I have reproduced the error, this seems like a bug. I will check this further and keep you updated.
ERROR: [VRFC 10-113] C:/Xilinx/Vivado/2016.3/data/xsim/vhdl/unisim/unisim.vdbl needs to be re-saved since std.standard changed
ERROR: [VRFC 10-147] unisim.vcomponents failed to restore
ERROR: [VRFC 10-149] 'vcomponents' is not compiled in library unisim [C:/Users/svanapar/Downloads/test.vhd:5]
Sravanthi
@svanapar, any progress on this issue?
@svanapar, any updates?
@svanapar, can you please provide an update on this issue?
@brian.trotter
Sorry that I didnt get chance to look into this. I will re-check this in latest version and update you soon.
Sravanthi
Observer dbanks12
@svanapar
Any update with this? I am running into the same problem with 2016.4.
David
Observer dbanks122
I am having this same problem with Vivado 2018.2 simulator. Is there any update with this @svanapar or @graces?
Hi guys, I am not sure if I will be helpful, but I believe I found the same problem in the 2018.3 version. It synthesizes but does not simulate. My solution was to set the compilation order manually in order to avoid missing 'references'.
