king32
Problem with the execution of SystemC files.
Hi there,
I'm using an open source tool for simulating and designing NoCs and I'm using ModelSim Student PE edition for the simulation. But when I want to compile the testbench described in SystemC, I get the following error :
# vmap -modelsim_quiet work work
# Modifying modelsim.ini
# ** Error: SystemC is not supported on win32pe_edu.
# Error in macro ./simulate_monitores.do line 6
I have set the environment variables and I have the license file in the ModelSim root. Is it because PE edition does not allow SystemC or is there something wrong?
Thank you for your help!
king32
Now I'm using the ModelSim PE Evaluation (a full license with full options!). Unfortunately, I have another error message right now! I have attached the message and I hope to find the solution to this tiny problem! I'm using x64 os and I installed GCC compiler for SystemC. May you please help me with this issue?
# Loading work.hermes_outport(hermes_outport_south)
# Loading work.routercc(routercc)
# Loading work.routerbl_monitor(routerbl_monitor)
# Loading work.reg16bit(reg16bit)
# Loading work.routertr_monitor(routertr_monitor)
# ** Error: Failure to license for systemc.Unable to checkout any of these license features: msimsystemc or msimsystemcnl.
# 1
Thank you very much.
