Problems in running simple LED code in Vivado SDK 2018.3
I am trying to run simple led code to test the working of GPIO. I will get following errors:
C:\Users\Awais\Desktop\Microzed\xadc\project_2\project_2.sdk\xadc2\Debug/../src/helloworld.c:58: undefined reference to `XGpioPs_LookupConfig'
C:\Users\Awais\Desktop\Microzed\xadc\project_2\project_2.sdk\xadc2\Debug/../src/helloworld.c:60: undefined reference to `XGpioPs_CfgInitialize'
C:\Users\Awais\Desktop\Microzed\xadc\project_2\project_2.sdk\xadc2\Debug/../src/helloworld.c:72: undefined reference to `XGpioPs_SetDirectionPin'
C:\Users\Awais\Desktop\Microzed\xadc\project_2\project_2.sdk\xadc2\Debug/../src/helloworld.c:73: undefined reference to `XGpioPs_SetOutputEnablePin'
C:\Users\Awais\Desktop\Microzed\xadc\project_2\project_2.sdk\xadc2\Debug/../src/helloworld.c:74: undefined reference to `XGpioPs_WritePin'
While the code is like this:
#include <stdio.h>
#include "platform.h"
#include "xadcps.h"
#include "xil_types.h"
#include "xil_printf.h"
#include "xplatform_info.h"
#include "xgpiops.h"
#include "xparameters.h"
#include <math.h>
#define XPAR_AXI_XADC_0_DEVICE_ID 0
#define ledpin 52
XGpioPs Gpio;
int main()
    int Status;
    XGpioPs_Config *GPIOConfigPtr;
    GPIOConfigPtr = (XGpioPs_LookupConfig(XPAR_PS7_GPIO_0_DEVICE_ID));
    Status = XGpioPs_CfgInitialize(&Gpio, GPIOConfigPtr, GPIOConfigPtr->BaseAddr);
    if (Status != XST_SUCCESS)
    return XST_FAILURE;
    printf("XGpio Setup Successful.\n\r");
    XGpioPs_SetDirectionPin(&Gpio, ledpin, 1);
    XGpioPs_SetOutputEnablePin(&Gpio, ledpin, 1);
    XGpioPs_WritePin(&Gpio, ledpin, 0x0);
    return 0;
I am not sure what is causing problem. If I try to write
GPIOConfigPtr = XGpioPs_LookupConfig(XPAR_PS7_GPIO_0_DEVICE_ID) in xparameters.h;
Then all errors will go away but it will give syntax error of
expected ';' before 'in'
Any workaround to solve this issue?
Solved this problem by enabling GPIO Pin in Zynq PS in IP integrator. I tried to activate through tcl script, but it did not get activated, so I activated manually.
