[Questa] (vopt-1127) Error message - "VHDL file ... not selected for default binding because it is out of date"
Hi All,
I've received the following error message while compiling the Vivado Project with Questa:
** Error (suppressible):
C:\Xilinx\Vivado\2018.3\data\ip\xilinx\c_counter_binary_v12_0\hdl\c_counter_binary_v12_0_vh_rfs.vhd(64):
(vopt-1127) Entity c_counter_binary_v12_0_12.c_counter_binary_v12_0_12_viv
was not selected for default binding because it is out of date
relative to dependency xbip_utils_v3_0_9.xbip_utils_v3_0_9_pkg, xbip_counter_v3_0_5.xbip_counter_v3_0_5_viv_comp,
c_counter_binary_v12_0_12.c_counter_binary_v12_0_12_pkg, xbip_counter_v3_0_5.xbip_counter_v3_0_5_pkg.
It seems the problem is with the precompiled VHDL libs...
How to solve?
Thank you!
回复: [Questa] (vopt-1127) Error message - "VHDL file ... not selected for default binding because it is out of date"
Yes, the error seems to indicate the pre-compiled library for the entity unit is out-of-date and needs to be re-compiled.
Have you successfully compiled 2018.3 simulation libraries targetting the current version of Questasim?
Does the modelsim.ini in use include the desired library mappings?
Yes, I recompiled ALL the Xilinx simulation libraries for Questa (Vivado -> Tools -> Compile Simulation Libraries -> Compile All Libraries for All Languagesa and All Families), but this did not help ...
As for the Questa, I have several versions installed on my PC - Questa 10.6d, Questa 10.7 ...
How does Questa knows what Xilinx libraries look for and there location?
Where the questa_lib should be mapped to? Here is how it appears in the Questa Project:
As you can see, it appears as "empty"... Should it be so? Actually the "C:/Projects/xgs/ex2sim/2019-04-30/questa/" is the directory where the Vivado Project Simulation for Questa was exported to (Vivado -> Export for Simulation ...)
"Does the modelsim.ini in use include the desired library mappings?" - yes, the libs are mapped in the modelsim.ini ...
Thank you
Is there any help? Idea?
How to solve this issue (default bounding and out-of-date entity)?
@ldm.eth  已写:
It looks to be related to another post created by you. Did you copy the new modelsim.ini created by compile_simlib (in the pre-compiled library location) to the simulation directory?
Here's the information about modelsim.ini search order extracting from Questasim User Guide.
Finds the modelsim.ini file by evaluating the following conditions:
o If the -modelsimini option is used, then the file path specified is used if it exists; else
o use $MODELSIM (which specifies the directory location and name of a modelsim.ini file) if it exists; else
o use $(MGC_WD)/modelsim.ini; else
o use ./modelsim.ini; else
o use $(MODEL_TECH)/modelsim.ini; else
o use $(MODEL_TECH)/../modelsim.ini; else
o use $(MGC_HOME)/lib/modelsim.ini; else
o set path to ./modelsim.ini even though the file does not exist
Environment Variables used: MODELSIM, MGC_WD, MGC_HOME
You can determine which modelsim.ini file was used by executing the where command.
As for questa_lib, this is neither a standard library nor a Xilinx simulation library. As anwered in the other post, I don't think it's necessary. Is it referenced and used in your simulation script?
"Did you copy the new modelsim.ini created by compile_simlib (in the pre-compiled library location) to the simulation directory?" - honestly, I don't remember ... Should I? How could this affect to the "out of date" error?
"As answered in the other post" - could you please provide a link to this post?
Re: [Questa] (vopt-1127) Error message - "VHDL file ... not selected for default binding because it is out of date"
Question for my knowledge,
is c_counter_binary_v12_0_12 a unisim library
@ldm.eth
Here's the other post I mentioned.
https://forums.xilinx.com/t5/Simulation-and-Verification/Migration-of-Questa-Project-from-one-PC-to-another-gt-Error-vopt/m-p/969035#M25830
You have to ensure the currently mapped libraries are up-to-date. If the simulation references libraries from legacy modelsim.ini, I think there'll be similar out of date complaint.
@drjohnsmith
It is an IP library.
