Newbie blhesterman
RTL Schematic omits connections
I tried viewing working VHDL code in the RTL Schematic viewer.  There is an 8-bit counter that is sitting alone with no connections.  I have produced working hardware with the code.  It also simulates correctly.  Is there some way to figure out why this counter is not connected in the schematic? I can't post the code, but I am looking for help in troubleshooting methods.
Re: RTL Schematic omits connections
Are you using ISE? What version?
You would be able to cross-probe the schematic objects to source code in PlanAhead tool, and then examine the associated connections in RTL.
Can you plese post the screenshot of your schematic? May be some system specific issue? Please check the schematic in other machine..
Thanks,Vijay
Historian
Historian
This occasional "missing connection in RTL schematic viewer" bug has existed in ISE for ages. And it will never be fixed.
Hi, I got the same situation, the rtl has ommitted some connections, is it normal?
Which version of software are you using? Can you please post the warnings which you are facing during synthesizing the design ? Are these connections omitted in Technology schematic as well ?
Ashish
Have you checked responses for your query? Are you still facing any issue with your design ?
Ashish
