Observer asanghi
RTL include file ERROR
I am putting some of the macros in a file and including this file in every file, where these macros are needed. However, when I compile for simulation, I get the following message.
ERROR: [Common 17-49] Internal Data Exception: HDDASrcFileProxy::HDDASrcFileProxy: Given HDDASrcFile isn't associated with a fileset. File: '/home/asanghi/project/valtix-hw/decompression/design/rtl/macros.v'
What is causing this error.
回复: RTL include file ERROR
If the include file has already been added to the project, please change its file type to Verilog Header.
It looks you launched the simulation from Vivado GUI.
Check the Sources window, is the include file seen under the Verilog Header directory? Following is an example figure.
Observer asanghi
Thank you for your response. No. the include file does not show up there. Also, the Sources window status is stuck in "Updating" mode with circular arrow rotating forever.
