RTL synthesis problem
HI All,
My name is Dasarath.
I am simulating the SATA with xilinx GTX ( virtex 6).
So i gave the unisims, unimacro,xilinxcorelib and secureip files as library files for compilation.
At simulation phase getting following error
ncsim: *E, ERRIPR error within protected source code.
In simulation doucment suggested that to use secureip libraries with IUS, an export control regulation license is required.
The above mentioned error becasue of this license or anything i am missing to provide to simulation tool.
regards
P Dasarath
Re: RTL synthesis problem
There was some issue in 13.x ISE with NCSIM.
I would suggest you to use 14.x version of tool.
There seems to be some libraries in the NCSIM secureip set which is causing this issue.
Try to use only GTEX1 library :
$XILINX/secureip/ncsim/gtxe1_ncsim/gtxe1_cell.list.f
How to do this?
Refer to single step process in http://www.xilinx.com/support/answers/31060.htm
Replace -f $XILINX/secureip/ncsim/ncsim_secureip_cell.list.f \
with
-f $XILINX/secureip/ncsim/gtxe1_ncsim/gtxe1_cell.list.f  \ (as you are using only GTX) and try.
Debraj
Which NCSIM version you are using?
XILINX library of which version?
Yash
Cadence Simulation tool is INCISIV 12.07.007
and Xilinx ISE 31.1
This is ncsim issue. please try using 12.20 or later version of tool.
or you can try using irun command.
for example refer below command:
irun \
+TESTNAME=sample_smoke_test0 \
-define NCV \
-define SIMULATION \
-define DISABLE_COLLISION_CHECK \
-timescale 1ns/1ps \
-access +rwc \
-incdir ../ \
-incdir ../../source \
-incdir ../../example_design \
-incdir ../tests \
-incdir ../dsport \
-k /dev/null \
+libext+.v+ \
-y $XILINX/verilog/src/simprims \
-y $XILINX/verilog/src/unisims \
$XILINX/verilog/src/glbl.v \
-file board_v.f \
${XILINX}/verilog/src/unisims/PCIE_2_0.v \
${XILINX}/verilog/src/unisims/GTXE1.v
FYI.. You have to modify this command according to your requirement.
Yash
Hi Yash,
Thanks for your response.
Even with Second options, getting the same error and i am unable to proceed.
The error should be related to compiling secureip sources.
Do you have an export control regulation license for IUS as documented in sim.pdf?
How to do this?
with
Debraj
