Visitor wuzidege
Re: Zero Defect Mindset
simultion of Multiply Accumulator
When I use the Multiply Accumulator IP Core simulation ,its configuration as:
input port A and B are set :14 bit ,signed. and the mac counter is set 200,clock rate is 50Mhz,result width is set 36bit.and assert the Reset  CE signals.
I simply instantiation the core.the ISE project as follows:
module demo(clk
       ,A
       ,B
       ,CE
       ,RST
       ,FD
       ,ND
       ,RDY
       ,Q
input clk;
input [13:0] A,B;
input RST;
input FD,ND;
input CE;
output RDY;
output [35:0] Q;
sine_macc inst_macc(
   .A(A),
   .B(B),
   .CLK(clk),
   .CE(CE),
   .RST(RST),
   .FD(FD),
   .ND(ND),
   .Q(Q),
   .RDY(RDY)
   ); // synthesis black_box
Endmodule
The simultaion result is strang,not like the datasheet that.
Input port A and B are set “00000000000001”in testbench,form the figure ,we can see that When CE is valid,Q is changed at the rising edge of clk,but the ND and FD is set zero.why the Q output port is changed?
