Read first mode, ring buffer
Hi!
I try to create a ring buffer using a Simple Dual Port RAM. I'm feeding both ADDR Pins with the same Addresses and the Clock at ClkA and ClkB is synchronous as well. I Would expect a delay of the full length of the RAM. In my case 1024. But I get only one clock delay caused by the output register of the RAM. In addition I get  Warnings like that:
Instance /top_tb/UUT/DualPortRAM_1/U0/ : Warning: blk_mem_gen_v2_8 WARNING: collision detected: A write address: 0000000000, B write address: 0000000000
I proofed that the read first mode is set in the VHDL-Modell. Do I have to set something else to get this work?
Greetings, Enrico.
Re: Read first mode, ring buffer
Enrico,
What are you doing with the write enable pins?  You are causing data write collisions since you are writing data to the same address ports.
I'm not sure I have worked with BlockRAMs to implement ring buffers so I can't immediately recommend a particular usage.  Hopefully other forum members can jump in and comment on the topic.
Eddie
