Reduce size of simulation
I am simulating for a long time with the BFM in 2016.4 version of Vivado.
My btree file is over 81 GB in the xsim directory
My simulate.log is 4.4G
the wdb which is 8 G
and the file I'm writing to, which is right, is 1.9 GB
My simulation is terminating since it's out of HD space.  How do I stop the sim from writing to btree and set a limit on simulate.log in the "launch_simulation" command?  Is there a different way to simulate from the command line to limit the size of these files?
Kurt
OK, I found this in the manual which controls 1 of the three:
In the Project Settings dialog box:
a. Click the Simulation category.
b. Select the Simulation tab.
c. Next to xsim.simulate.xsim.more_options add -maxlogsize where is the maximum amount of text output in megabytes.
One down - two to go.... Anyone?
Hi @petersk,
The .btree file is a temporary file that is used to build the wdb. The simplest method to reduce the size of it is to reduce the number of signals that are being simulated, along with the time the simulation is being run for. Understandably this isn't always possible.
What may help is to use the wdb file and the wcfg files to view the saved simulation data with the following command
xsim name.wdb -view name.wcfg -gui
It won't help with the file sizes but may give you a boost in speed as you are not rerunning simulations.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
I tried to reduce the number of signals with:
 relaunch_sim
 log_wave /tb/tb_ACLK
 run all
Unfortunately, it seems like the wdb file runs at the same rate!
Why isn't that shrinking the file?
Hi @petersk,
Can you check in simulation settings under simulation tab , "xsim.simulate.log_all_signals*"    option is unchecked?
No, it is not checked.  Any other thoughts?
I am now trying to export simulation.  What is a way that I could limit the wdb size through the same kind of tcl command for that?
Is there any way to stop btree from being so large.  It's really killing me!  Google tells me very little about it and your docs don't show how it is used and reduced.
Kurt
