buddha1987
Voyager
Voyager
Reuse the tcl file generate thru nativelink by Vivado for simulationin Questa (or Modelsim)
I use Vivado nativelink to generate do file for simulation. This saves a lot time since I don't need to write the tcl by myself.
However.  I found a big problem when I try to reuse the generated do file thru run the do file in Questa as :
do  sim.do
But it seems I always confront problems. The format of generated do file is always like:
vlib work
vlib msim/blk_mem_gen_v8_1
vlib msim/fifo_generator_v11_0
vmap blk_mem_gen_v8_1 msim/blk_mem_gen_v8_1
vmap fifo_generator_v11_0 msim/fifo_generator_v11_0
It seems:
1. Questa can't create directory using command like : vlib msim/blk_mem_gen_v8_1
2. It seems all previous generated files, directorys need to be deleted before Questa run the do file again.
So anyone have idea how I should modify the do file generated by Vivado to reuse?
Thanks very much.
buddha1987
Voyager
Voyager
Anyone has idea?
dprasad
In do file, at top, please write following command
\rm -rf work
\rm -rf msim/*
This will clean the previous dump so you should not see the issue on re-run.
buddha1987
Voyager
Voyager
Thanks. So the only thing I need to do before is delete work directory and msim directory?
dprasad
Don't delete the msim directory completely rather delete the content of msim directory i.e msim/*
buddha1987
Voyager
Voyager
It seems no matter I completely delete msim or just delete content of msim, both works.
