gaochaoant
RocketIO GTP simulation.Help me,please!
I use RocketIo GTP v9.1,but I can not simulate it.Please help me!
The error is :
# ** Note: (vsim-3813) Design is being optimized due to module recompilation...
# ** Note: (vsim-3865) Due to PLI being present, full design access is being specified.
# ** Error: D:/Xilinx/10.1/ISE/vhdl/src/unisims/unisim_SECUREIP.vhd(2329): No default binding for component 'gtp_dual_swift'. (Port 'do' is not on the entity.)
# ** Warning: [1] (vopt-3473) Component instance "gtp_dual_swift_bw_1 : gtp_dual_swift" is not bound.
# ** Error: D:/Xilinx/10.1/ISE/vhdl/src/unisims/unisim_SECUREIP.vhd(2690): No default binding for component 'gtp_dual_fast'. (Port 'do' is not on the entity.)
# ** Warning: [1] (vopt-3473) Component instance "gtp_dual_fast_bw_1 : gtp_dual_fast" is not bound.
edv
This typically occurs if you've installed the latest Service Packs and IP Updates for 10.1, but have yet to re-compile the simulation libraries.  Make sure you ran the Simulation Libraries Compilation Wizard (compxlib) after installing the latest updates.
Hope this helps.
Eddie
gaochaoant
Thank you for your advise!
I compiling the library again,but it seems to have no effect.
edv
Due to the number of factors that are involved in setting up  your simulator environment, please consider opening a WebCase in order to have an Applications Engineer help you further with this issue.
Eddie
gaochaoant
Thank you very much!
Could you tell me how to get the help from WebCase?
edv
Click on the "WebCase" link on my previous message. From there, just use the "Login" button to enter your xilinx.com info and file a new WebCase.
Eddie
