ramyakv
Run simulation
I am running a code but when I click on simulation..it runs forever...
How do I complete simulation and see results.
graces
You may click the Background button to move the progress bar to the bottom. Check the Tcl console to see at what phase it's running.
bruce_karaffa
You can always click cancel to stop the simulation.  You could also use a commend like "run 1 ms" to only run for one millisecond of simulation time.
ramyakv
 this is the simulation settings I hvae done
ramyakv
 i am unable to take your approach...can u please suggest after looking into simulation settings
dpaul24
@ramyakv ,
1st of all you should learn how to post information in a forum. It is difficult for us to extract info from screenshots (that too when pictures are 90 deg rotated) and guess the reasons for failure.
I saw this thread today morning but declined to comment for obvious reasons!
Some examples, but not limited to....
Post RTL code within code-tags </> or as an attached file.
Describe your scenario and problem a bit, be verbose (what do you what to achieve, what you have done up to now, etc).
Post waveform screenshots with proper resolution and orientation.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
ramyakv
@dpaul24
i was trying to test a present cipher code which  i had downlaoded from github.
I wanted to run in vivado platform.
i have attatched all the files used for my work.
i have added a testbench verilog file for simulation, but simulation keeps running forever.
can you please suggest me what modifications should i do .
regards
ramya
ramyakv
@dpaul24
Files that are used for my work
