Running Microblaze simulation using PlanAhead 14.5 generated design on ModelSim 10.2
I am hoping that someone could point me to a tutorial on running simulation using ModelSim. I have generated the design using PlanAhead 14.5 design flow and XPS.
When I generate the testbench I am not seeing the configuration to use the appropriate bram loaded with the code.
I am hoping that there is a tutorial the explains the helloworld for the ModelSim based simulation.
Thanks in advance.
Re: Running Microblaze simulation using PlanAhead 14.5 generated design on ModelSim 10.2
http://www.xilinx.com/support/documentation/application_notes/xapp1003.pdf may help! Though its for Power PC, the simulation flow is useful for begineers.
Debraj
This user guide only discusses 10.0 tools of XPS and ISE. Things have changed considerably in 14.5. I am using PlanAhead tool chain that is different than ISE.
Would apprecate any doc that describes 14.5 tools. Thanks.
How about this one:http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/platform_studio/platform_studio_start.htm
Debraj
