rodmcinnis
SIP_GTYE4_COMMON, SIP_GTYE4_CHANNEL
I am trying to run a simulation on an example design that was created by Vivado.  The IP that the example design was for was the "gtwizard_ultrascale_0_ex"
I am using Vivado, 2018.3
I an using Modelsim for the simulator.  I have re-run the Xilinx "Compile Simulation Libraries" tool to ensure that my Modelsim libraries are up to date.  I clock on the "Run Simulation" arrow in the flow navigator and Modelsim launches and attempts to execute the "do" list.
Unfortunately, it errors out, unable to find SIP_GTYE4_COMMON and SIP_GTYE4_CHANNEL
Error: (vsim-3033) D:/Xilinx/Vivado/2018.3/data/verilog/src/unisims/GTYE4_CHANNEL.v(3935): Instantiation of 'SIP_GTYE4_CHANNEL' failed. The design unit was not found.
** Error: (vsim-3033) D:/Xilinx/Vivado/2018.3/data/verilog/src/unisims/GTYE4_COMMON.v(942): Instantiation of 'SIP_GTYE4_COMMON' failed. The design unit was not found.
I am guessing that there is a library missing but I can't figure out which one.  Here is the command line that the tool generated, showing the libraries it called out:
vsim -voptargs="+acc" -L gtwizard_ultrascale_v1_7_5 -L xil_defaultlib -L unisims_ver -L unimacro_ver -L secureip -L xpm -lib xil_defaultlib xil_defaultlib.gtwizard_ultrascale_0_example_top_sim xil_defaultlib.glbl
Can someone help me out here?
Rod
bandi
Hi @rodmcinnis ,
Glad to know that this issue is solved. can you please close this thread by marking the post which helped as accepted solution.
Thanks & Regards,
Sravanthi B
bandi
Hi @rodmcinnis ,
Can you please share the compile_simlib.log file and the Vivado.log to check at our end.
Thanks & Regards,
Sravanthi B
graces
Hello Rod,
As Sravanthi as pointed out, please ensure compile_simlib completed without any errors for the target Modelsim verison.
If you launch Modelsim from within Vivado GUI, the tool should be able to generate the correct simulation script with all necessary libraries referenced. Did you specify the pre-compiled library location in the Simulation Settings? This allows modelsim.ini with pre-compiled library mappings to be copied to the current simulaiton directory, so that the libraries can be found.
rodmcinnis
It turned out to be that compile_simlib failed
Thank you for  your help.
Rod
bandi
Hi @rodmcinnis ,
Thanks & Regards,
Sravanthi B
