lokeshxilinx
SPANSION FLASH INTERFACE WITH SPARTAN 3AN FOR WRITE AND READ THE DATA BYTES USING SPI PROTOCOL
Dear all.....
           Here the verilog code and simulation model for write/read the single byte of data into the specific address byte of the flash s25fl204k memory using SPI Protocol which is 4-wire  MOSI,MISO,CS,SCK are Configured for normal dual(I/O) pins of SPARTAN-3an FPGA.
HERE THE PROTOCOL BYTES  I USED TO WRITE/READ THE DATA BYTES BASED ON DATASHEET OF spansion S25FL204K THE ABOVE FLASH
BYTE READ
FOR MOSI( RISING EDGE OF SCK )
*Byte one   - 03h(code for read)
*Byte 2,3,4 - address byte 24bit
*byte 5     -dont care
FOR MISO ( FALLING EDGE SCK  )
*during byte 5 of MOSI
BYTE WRITE*Byte one   - 06h(WRITE ENABLE)
*Byte 2     -02h (code for pag program)
*3,4,5 - address byte 24bit
*byte 6    -data = 8'h10101010
The  simulation waveform  is  attached in the below jpeg picture
can any tell me this is the correct procedure for access the spansion flash with fpga .thak you
