Jennifer_Holt
Segfault when running simulation. 2020.2
I am trying to improve my testbenches and am basing my efforts on some guides from https://verificationguide.com/
Specifically I am trying to duplicate the following in vivado 2020.2: https://www.edaplayground.com/x/2527
I created the files and made a simple project, however when I try to simulate it, I get the following error:
Compiling package xil_defaultlib.$unit_design_sv
ERROR: [XSIM 43-3316] Signal SIGSEGV received.
Printing stacktrace...
[0] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x539afd]
[1] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x646536]
[2] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x64a546]
[3] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x64a887]
[4] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x6582e0]
[5] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x66cb21]
[6] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x79d03f]
[7] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x79de38]
[8] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x54a7de]
[9] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x981dd5]
[10] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x94b150]
[11] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x51faa2]
[12] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x5355e9]
[13] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x4b7f54]
[14] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fc1d9bc5bf7]
[15] /data/opt/Xilinx/Vivado/2020.2/bin/unwrapped/lnx64.o/xelab() [0x51e3b7]
I am using Vivado 2020.2 on Ubuntu 18.04. I have attached the archived project.
Jenn Holt
bandi
Hi @Jennifer_Holt ,
Thanks  for sharing the test case. I have reported this issue to the factory.
Thanks & Regards,
Sravanthi B
