dpaul24
Setting environment variable for Viv2020.2 under Win10
Hello I am using Vivado 2020.2 and want to set the set the xsim simulator path.
I read this thread and understood that if I run C:\vivado\Vivado\*\settings64.bat then the environment variable would be set, but it does not work.
So which path shall I add for 2020.2?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
richardhead
I generally just do it manually: I add C:\Xilinx\Vivado\<version>\bin  to the PATH variable, with the one I want to use most often as the heighest in the list.
I then create separate variables so I can call a specific version from the command line, eg:
VIVADO19.2 : C:\Xilinx\Vivado\2019.2\bin\vivado
And in a command window I can simply write:
%VIVADO19.2% -mode batch -source ....etc
