davidgander
Setting signal radix and adding groups in ISIM with tcl
Hello, I'm currently using tcl scripts to setup simulations in ISIM 11.1 (using 'wave add ' ) . Is there a way to change the radix of the signals I add and combine them into groups using tcl. I can only seem to do this at the moment by right clicking on the signals. Searching through the ISIM documentation has references to changing the radix but I believe it's referring to how arguments are interpreted rather than how signals are displayed. Many thanks, David
Message Edited by davidgander on 04-06-2010 04:17 AM
duthv
Hi David,
This capability will be available in the 12.1 release that will be available in early May.
Duth
duthv
Hi David,
Duth
