Setting up clock wizard doubt
Hi guys,
I have one doubt in using the clock wizard in the IP intregrator design. My FPGA, VC707 provides differential clock signals individually, however the clock wizard requires a single clock label for its differential input. After checking the master file of the FPGA I notice that this signal is not provided.
Please see the picture:
Can anyone tell me how can I fix this problem?
Please see attached the .xdc file for my FPGA.
Many thanks,
Rodolfo
Re: Setting up clock wizard doubt
That is mostly correct. You have to change the IOSTANDARD lines to sys_diff_clock_clk_p/n too.
Voyager
Voyager
That is an interface not a signal.  Did you try connection automation?
If not, take a look at your top level wrapper and you should see an _p and an _n version of the ports.
Assign the _p to the pad based on your XDC/UCF/schematic.
If you did use connection automation (I haven't used the VC709 in awhile), it should automatically get connected to the correct pads assuming you selected the correct board level interface when prompted.  You can verify this by opening your synthesized design and seeing where the pins were assigned.
***Many of us who help you are just FPGA enthusiasts, and not Xilinx employees. If you receive help, and give kudos (star), you're likely to continue receiving help in the future. If you get a solution, please mark it as a solution.***
Hi morgan,
Many thanks for your reply.  I understood waht you mean, but can you just confirm this is the right procedure:
1) I did use the connection automation to get the respective labels, as you can see:
2) Then I create the HDL wrapper of the design, wich assigned the clock as:
3) I edit the master file of the FPGA and placed the labels sys_diff_clock_clk_n and sys_diff_clock_clk_p in the right pins:
Is this the right procedure?
Many thanks,
Rodolfo
Many thanks, now I get it!
