cja@ike.no
Sim problems with FIFO_DUALCLOCK_MACRO
I'm trying to compile my design using the FIFO_DUALCLOCK_MACROs, but I get an error message reporting some issue with the Macro itself. Does anyone know how to get around this?
ERROR: [VRFC 10-704] formal rdcount has no actual or default value [/proj/buildscratch/builds/2014.2/continuous/20140611
121610/data/vhdl/src/unimacro/FIFO_DUALCLOCK_MACRO.vhd:53]
ERROR: [VRFC 10-704] formal wrcount has no actual or default value [/proj/buildscratch/builds/2014.2/continuous/20140611
121610/data/vhdl/src/unimacro/FIFO_DUALCLOCK_MACRO.vhd:55]
ERROR: [XSIM 43-3321] Static elaboration of top level VHDL design unit analogfrontendtb in library work failed.
ERROR: [Runs 36-25] xelab application returned error(s). Please see 'd:/Projects/GuardRec/xDC/FPGA/sim/prj/xdc_audio_afe
_sim/xdc_audio_afe_sim.sim/sim_1/behav/xelab.log' file for more details.
ERROR: [Common 17-69] Command failed: Failed to compile the design!
Another question about the instance: I'm using a zynq-7010 device, but in the source it does not say anything about zynq-support, only "7series"....does it not support Zynq?
br,
cja
vemulad
signal tmp1: std_logic_vector(9 downto 0);
signal tmp2 : std_logic_vector(9 downto 0);
Declare two dummy signals and connect them to RDCOUNT and WRCOUNT ports of the macro respectively.
RDCOUNT => open errors out but RDCOUNT=> tmp1(9 downto 0) does not.
Single bit output ports can be left unconnected (OPEN) but vector ports do need a width specified even if unused.
Hope this helps.
Deepika.
Deepika.
vemulad
If it supports 7 series it supports Zynq too.
Can you show us the instantiation of macro in your design?
Can you make sure that you are following the instantiation template provided at page-61 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug953-vivado-7series-libraries.pdf
Deepika.
Deepika.
cja@ike.no
Here is my instance:
u1_ch1 : entity unimacro.FIFO_DUALCLOCK_MACRO
    generic map (
      DEVICE                  => "7SERIES",  -- Target Device: "VIRTEX5", "VIRTEX6", "7SERIES"
      ALMOST_FULL_OFFSET      => X"0100",    -- Sets almost full threshold
      ALMOST_EMPTY_OFFSET     => X"0100",    -- Sets the almost empty threshold
      DATA_WIDTH              => 36,  -- Valid values are 1-72 (37-72 only valid when FIFO_SIZE="36Kb")
      FIFO_SIZE               => "36Kb",     -- Target BRAM, "18Kb" or "36Kb"
      FIRST_WORD_FALL_THROUGH => false)  -- Sets the FIFO FWFT to TRUE or FALSE
    port map (
      ALMOSTEMPTY => open,
      ALMOSTFULL  => fifoAlmostFull(1),
      DO          => dataFromFifoCh1,
      EMPTY       => open,
      FULL        => open,
      RDCOUNT     => open,  --RDCOUNT,  -- Output read count, width determined by FIFO depth
      RDERR       => open,
      WRCOUNT     => open,  --WRCOUNT,  -- Output write count, width determined by FIFO depth
      WRERR       => open,
      DI          => dataToFifoCh1,
      RDCLK       => clk,
      RDEN        => fifoReadEnable(1),
      RST         => reset,
      WRCLK       => sclk,
      WREN        => fifoWriteEnable(1));
I copied the instance from UG953...
-cja
vemulad
Hope this helps.
Deepika.
Deepika.
cja@ike.no
OK, this works. But, I am not sure I like this. To create unnecessary dummy signals only creates unwanted "mess" in my code....
-cja
