Simple behavioral Simulation does not match run
Hi!
I am trying to simulate a simple microblaze system with GPIO output to LEDs. The LEDs are being blinked by the microblaze.
My simulation either shows nothing, or I am misguided about the waveforms I should be looking at, since nothing seems to be happening on the GPIO - but this works in reality!  I can control blinking of the LEDs when programming the AC701 directly.
I am attaching my testbench, waveform, and block diagram.
module test_bench(
    reg sys_clk_pin_p;
    reg sys_clk_pin_n;
    reg sys_rst_pin;
    //wire [3:0] LED;
    design_1_wrapper DUT(
        .led_4bits_tri_o(),
        .reset(),
        .rs232_uart_rxd(),
        .rs232_uart_txd(),
        .sys_diff_clock_clk_n(sys_clk_pin_n),
        .sys_diff_clock_clk_p(sys_clk_pin_p)
    initial
          begin
            sys_clk_pin_p <= 1'b0;
            sys_clk_pin_n <= 1'b1;
            sys_rst_pin <= 1'b1;
            #1000 sys_rst_pin <= 1'b0;
            $display("INITIAL");
          end
//This sets our clock frequency
    always #2.5 sys_clk_pin_p <= ~sys_clk_pin_p;
    always #2.5 sys_clk_pin_n <= ~sys_clk_pin_n;
endmodule
Scholar dpaul24
Re: Simple behavioral Simulation does not match run
@simchask,
I really cannot tell how your design works in real hardware.
But the sim problem is clear.
You have NOT properly port-mapped your design! Only your differential clock is connected.
The uB reset needs to be properly connected.
FPGA enthusiast!
All PMs will be ignored
Thank you, you are right, but I already noticed this.
Fixing that did not correct the problem of no output.
"I really cannot tell how your design works in real hardware."
I'm not sure if you are saying that you don't understand why it should work, or if you need more information.
I will post my SDK code as well:
#include "xparameters.h"
#include "xil_printf.h"
#include "xstatus.h"
#include "xil_cache.h"
#include "xgpio.h"
#include "gpio_header.h"
#define LED_CHANNEL 1
#if SIM
	#define LED_DELAY 1
#else
	#define LED_DELAY 10000000
#endif
int main ()
   Xil_ICacheEnable();
   Xil_DCacheEnable();
   XGpio GpioOutput;
   XGpio_Initialize(&GpioOutput, XPAR_AXI_GPIO_0_DEVICE_ID);
   XGpio_SetDataDirection(&GpioOutput, LED_CHANNEL, 0x0); //All 0 is all output
     	  u32 Delay = 0;
	  xil_printf("starting\n\r");
      while (1) {
      		/* Set the LED to High */
      		XGpio_DiscreteWrite(&GpioOutput, LED_CHANNEL, 0x7);
      		xil_printf("flash\n\r");
      		/* Wait a small amount of time so the LED is visible */
      		for (Delay = 0; Delay < LED_DELAY; Delay++);
      		/* Clear the LED bit */
      		XGpio_DiscreteClear(&GpioOutput, LED_CHANNEL, 0x7);
   xil_printf("---Exiting main---\n\r");
   Xil_DCacheDisable();
   Xil_ICacheDisable();
   return 0;
Looking at the ILMB_readdbus signal, I see only two values alternating between themselves.
If I guess correctly that this is the bus transferring commands to the microblaze from BRAM, then this seems off.
But I have no idea why.
And the inst_addr signal from the microblaze is going from 0, to 4, to 8 and then repeats itself. So clearly the microblaze is not processing the program. But since I loaded the ELF file into the simulation sources, and it seems I am providing the necessary signals to the top level wrapper...I am clueless as to why.
