Simulating VHDL from exported HLS does not behave as expected
I have a several IPs designed in VHDL. For implementation and testing purposes, I an not doing anything in a block design but pure VHDL. The thing is that I need to incorporate one HLS IP into the architecture and keep testing it without recurring to a block design.
To test the correct behavior of the exported HLS IP, I only included the VHDL files generated by vivado HLS and wrote a testbench in VHDL. The HLS code is described here in detail as I thought there was a problem with HLS. It basically receives a stream of bytes (via AXI Stream) that represent RGB images. So, I split each channel to further process them individual to later group them together by forming the AXI Stream frame back in the same RGB order. In this case, as I just want to prove the methodology, there is no processing but copying the input bytes to the output.
This is the simulation result I obtained using Vivado 2017.4:
Here the output does not match the input which is the expected behavior. Therefore, I created a block design and I only managed to obtain the correct output by placing an AXI4 FIFO at the input and output of my HLS IP:
By using *the same testbench* as in the first test, I got the expected output (output = input with a delay):
To be sure that there was no problem with an old Vivado version, I did the same test with Vivado 2019.2 and 2020.1. The design with the block design matched the one shown above, a correct behavior. However, simulating VHDL without a block design showed another result (again using the same VHDL module and testbench)
I could generate a complete block design with all VHDL and HLS IPs. However, this is too time consuming for debuging as every time there is something to change in the VHDL modules, I would need to edit each exported IP, generate output products and then simulate. Contrary to having directly all VHDL files in the Project Manager and making changing directly to run simulation afterwards easily.
So, what is the issue that I don't get the same and correct behavior when adding the exported VHDL files from an exported HLS IP in simulation? I attached the testbenches for the simulations with and without a block design and the top vhdl module instantiating the VHDL files from the HLS IP. The HLS files are in the thread linked at the beginning.
Thanks for the help.
Re: Simulating VHDL from exported HLS does not behave as expected
 stimulus: process
    variable s_counter_count :integer := 0;
  begin
    -- Put initialisation code here
    S_AXIS_0_tdata <= (others=>'0');
    S_AXIS_0_tvalid <= '0';
    S_AXIS_0_tlast <= '0';
    M_AXIS_0_tready <= '1';
    s_axis_aresetn_0 <= '0';
    wait for 1*clock_period;
    s_axis_aresetn_0 <= '1';
    wait for 10*clock_period;
    wait until s_axis_aclk_0 = '0' ;
    S_AXIS_0_tvalid <= '1';
    s_counter_count := 0;
    while(s_counter_count<12) loop
        if M_AXIS_0_tready='1' then
            S_AXIS_0_tdata <= stream(95 downto 88);
            stream <= stream(87 downto 0) & "00000000";
            if(s_counter_count=12-1) then   -- TotalBytes - 1
                S_AXIS_0_tlast <= '1';
            else
            end if;
            s_counter_count := s_counter_count + 1;
        end if;
    end loop;
    -- Put test bench stimulus code here
    wait;
  end process;
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
@aripod
The design is correct, the problem is on the test bench.
The signals must be delayed by at least one delta-delay with respect to the clock.
How do you add a delta cycle delay? Just with `after`?
    M_AXIS_0_tready <= '1' after 1 ns;
    S_AXIS_0_tvalid <= '1' after 1 ns;
        if S_AXIS_0_tready='1' then
            S_AXIS_0_tdata <= stream(95 downto 88)  after 1 ns;
                S_AXIS_0_tlast <= '1' after 1 ns;
            else
                S_AXIS_0_tlast <= '0' after 1 ns;
            end if;
        end if;
        wait for clock_period;
    end loop;
This didn't work.
 stimulus: process
  begin
            else
            end if;
        end if;
    end loop;
    wait;
  end process;
@calibragreat, that is perfect. Thanks.
@calibra  One thing I noticed now is that as it waits until the clk=0, then this whole part is in sync with the falling edge of the clock and my entire system is in sync with the rising edge of the clock and that causes some synchronization issues.
Because your design is syncronized  with the rising edge it is more easy to understand the waveform if the testbench is syncronized  with the falling edge.
You said "that causes some synchronization issues."
Why ?
@calibra  it worked. I just tried with a very simple axi stream passthrough in vhdl for the input and output and in the middle the HLS IP (also passthorugh) and it worked as expected, with the original testbench. I believe that this axis in VHDL are doing the same as the FIFOs in the block design as an interface from/to the HLS IP. Just to have things clear:
top.vhd:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity top is
  port (
    M_AXIS_0_tdata : out STD_LOGIC_VECTOR ( 7 downto 0 );
    M_AXIS_0_tlast : out STD_LOGIC;
    M_AXIS_0_tready : in STD_LOGIC;
    M_AXIS_0_tvalid : out STD_LOGIC;
    S_AXIS_0_tdata : in STD_LOGIC_VECTOR ( 7 downto 0 );
    S_AXIS_0_tlast : in STD_LOGIC;
    S_AXIS_0_tready : out STD_LOGIC;
    S_AXIS_0_tvalid : in STD_LOGIC;
    s_axis_aclk_0 : in STD_LOGIC;
    s_axis_aresetn_0 : in STD_LOGIC
end top;
architecture behavior of top is
    signal s_in_tdata, s_out_tdata : std_logic_vector(7 downto 0);
    signal s_in_tvalid, s_out_tvalid : std_logic;
    signal s_in_tlast, s_out_tlast : std_logic;
    signal s_in_tready, s_out_tready : std_logic;
    signal s_in_hls_tlast, s_out_hls_tlast : std_logic_vector(0 downto 0);
begin
    axis_in: entity work.axis(behavior)
      port map(
        M_AXIS_0_tdata => s_in_tdata,
        M_AXIS_0_tlast => s_in_tlast,
        M_AXIS_0_tready => s_in_tready,
        M_AXIS_0_tvalid => s_in_tvalid,
        S_AXIS_0_tdata => S_AXIS_0_tdata,
        S_AXIS_0_tlast => S_AXIS_0_tlast,
        S_AXIS_0_tready => S_AXIS_0_tready,
        S_AXIS_0_tvalid => S_AXIS_0_tvalid,
        s_axis_aclk_0 => s_axis_aclk_0,
        s_axis_aresetn_0 => s_axis_aresetn_0
    s_in_hls_tlast(0) <= s_in_tlast;
    s_out_tlast <= s_out_hls_tlast(0);
    passthrough_0: entity work.Passthrough(behav)
      port map(
          input_r_TDATA => s_in_tdata,
          input_r_TLAST => s_in_hls_tlast,
          output_r_TDATA => s_out_tdata,
          output_r_TLAST => s_out_hls_tlast,
          ap_clk => s_axis_aclk_0,
          ap_rst_n => s_axis_aresetn_0,
          input_r_TVALID => s_in_tvalid,
          input_r_TREADY => s_in_tready,
          output_r_TVALID => s_out_tvalid,
          output_r_TREADY => s_out_tready
    axis_out: entity work.axis(behavior)
        port map(
          M_AXIS_0_tdata => M_AXIS_0_tdata,
          M_AXIS_0_tlast => M_AXIS_0_tlast,
          M_AXIS_0_tready => M_AXIS_0_tready,
          M_AXIS_0_tvalid => M_AXIS_0_tvalid,
          S_AXIS_0_tdata => s_out_tdata,
          S_AXIS_0_tlast => s_out_tlast,
          S_AXIS_0_tready => s_out_tready,
          S_AXIS_0_tvalid => s_out_tvalid,
end behavior;
axis.vhd ("interfaces" to HLS?):
library IEEE;
entity axis is
  port (
end axis;
architecture behavior of axis is
begin
    M_AXIS_0_tdata <= S_AXIS_0_tdata when (S_AXIS_0_tvalid='1' and M_AXIS_0_tready='1') else (others=>'0');
    M_AXIS_0_tvalid <= '1' when S_AXIS_0_tvalid='1' else '0';
    M_AXIS_0_tlast <= '1' when ((S_AXIS_0_tvalid='1' and S_AXIS_0_tlast='1') and M_AXIS_0_tready='1') else '0';
    S_AXIS_0_tready <= '1' when M_AXIS_0_tready='1' else '0';
end behavior;
and the testbench:
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity top_tb is
end;
architecture bench of top_tb is
  component top
    port (
  end component;
  signal M_AXIS_0_tdata: STD_LOGIC_VECTOR ( 7 downto 0 );
  signal M_AXIS_0_tlast: STD_LOGIC;
  signal M_AXIS_0_tready: STD_LOGIC;
  signal M_AXIS_0_tvalid: STD_LOGIC;
  signal S_AXIS_0_tdata: STD_LOGIC_VECTOR ( 7 downto 0 );
  signal S_AXIS_0_tlast: STD_LOGIC;
  signal S_AXIS_0_tready: STD_LOGIC;
  signal S_AXIS_0_tvalid: STD_LOGIC;
  signal s_axis_aclk_0: STD_LOGIC;
  signal s_axis_aresetn_0: STD_LOGIC;
  constant clock_period: time := 10 ns;
  signal stop_the_clock: boolean;
  signal stream : std_logic_vector(95 downto 0) := x"111213212223313233414243";
begin
  uut: top port map ( M_AXIS_0_tdata   => M_AXIS_0_tdata,
                                   s_axis_aresetn_0 => s_axis_aresetn_0 );
  stimulus: process
  begin
            else
            end if;
        end if;
    end loop;
    wait;
  end process;
  clocking: process
  begin
    while not stop_the_clock loop
      s_axis_aclk_0 <= '1', '0' after clock_period / 2;
    end loop;
    wait;
  end process;
end;
Which is the original one, without `wait until clk='0'`.
The result is as expected:
Now the question is why that sort of a vhdl-hls "interface" is needed?
Your testbench is wrong.
On the first iteration S_AXIS_0_tready='0'.
When you set S_AXIS_0_tvalid = '1', S_AXIS_0_tready ='1' some delta delays later.
@calibra  why do you say that S_AXIS_0_tready='0' on the first iteration? It is set to 1 followed by some clock periods (to toggle the reset signal).Do you mean that tvalid will be zero on the first iteration? If that is the case, I added the wait until tvalid=1. However, there is no difference with that wait. I might have understood you wrongly.
    wait until S_AXIS_0_tvalid='1';
It is
wait until S_AXIS_0_tready='1' ;
The problem is actually that the test bench is not well constructed.
@calibra  How should be well constructed?. thanks for the help.
My problem remains. Using the same testbench, I replaced those "interface" modules with some real functionality and I got the expected results. The goal is to receive a stream of bytes and convert it to parallel. The special thing here is that the first 16 bytes (4x32 bit value) are independent and the last 12 bytes are meant to be broadcaster further also as axi stream:
library IEEE;
use ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
entity axisToIP is
    generic (
        BYTES   : natural := 17;
        BITS    : natural := 8
    Port (
        clk : in std_logic;
        rst : in std_logic;
        -- AXIS Slave
        s_axis_tvalid               : in std_logic;
        s_axis_tdata                : in std_logic_vector (7 downto 0);
        s_axis_tlast                : in std_logic;
        s_axis_tready               : out std_logic;
        -- Message definition
        total_length                : out std_logic_vector (31 downto 0);
        height                      : out std_logic_vector (31 downto 0);
        width                       : out std_logic_vector (31 downto 0);
        data_length                 : out std_logic_vector (31 downto 0);
        data_tdata                  : out std_logic_vector (7 downto 0);
        data_tvalid                 : out std_logic;
        data_tlast                  : out std_logic;
        data_tready                 : in std_logic
end axisToIP;
architecture Behavioral of axisToIP is
    --  Variable        --  Bits    --  Bytes   --  Count
    -- total_length     -- 32       --  4       --  0, 1, 2, 3
    -- height           -- 32       --  4       --  4, 5, 6, 7
    -- width            -- 32       --  4       --  8, 9, 10, 11
    -- data_length      -- 32       --  4       --  12, 13, 14, 15
    -- data             -- 8        --  1       --  16
    signal s_total_length_A, s_total_length_B, s_total_length_C, s_total_length_D : std_logic_vector(7 downto 0) := (others=>'0');
    signal s_total_length : std_logic_vector(31 downto 0) := (others=>'0');
    signal s_total_length_A_ce, s_total_length_B_ce, s_total_length_C_ce, s_total_length_D_ce : std_logic := '0';
    signal s_height_A, s_height_B, s_height_C, s_height_D : std_logic_vector(7 downto 0) := (others=>'0');
    signal s_height : std_logic_vector(31 downto 0) := (others=>'0');
    signal s_width_A, s_width_B, s_width_C, s_width_D : std_logic_vector(7 downto 0) := (others=>'0');
    signal s_width : std_logic_vector(31 downto 0) := (others=>'0');
    signal s_data_length_A, s_data_length_B, s_data_length_C, s_data_length_D : std_logic_vector(7 downto 0) := (others=>'0');
    signal s_data_length : std_logic_vector(31 downto 0) := (others=>'0');
    signal s_counter_count : std_logic_vector(31 downto 0) := (others=>'0');
    signal s_axis_counter_count : std_logic_vector(31 downto 0) := (others=>'0');
    signal s_counter_rst, s_axis_counter_rst: std_logic := '0';
    signal s_counter_CE, s_axis_counter_CE: std_logic;
    signal tmp : std_logic_vector(7 downto 0);
begin
    s_counter_CE <= (s_axis_tvalid and data_tready) when (s_counter_count=16 and s_axis_counter_CE='0') else
                    '1' when ((s_axis_tvalid='1' and s_axis_counter_CE='0') or s_axis_counter_rst='1') else '0';
    s_counter_rst <= '1' when (s_counter_count = 16 and s_axis_counter_rst='1') else '0';
    s_axis_counter_CE <= '1' when
                            (s_counter_count = 16 and data_tready='1') else
                             '0';
     s_axis_counter_rst <= '1' when
                            ((s_counter_count = 16 and s_axis_counter_count=s_data_length-1))
                            else '0';
    counters: process(clk)
    begin
        if(rising_edge(clk)) then
            if(s_counter_rst='1') then
                s_counter_count <= (others=>'0');
            elsif(s_counter_CE='1') then
                s_counter_count <= s_counter_count + '1';
            end if;
            if(s_axis_counter_rst='1') then
                s_axis_counter_count <= (others=>'0');
            elsif(s_axis_counter_CE='1') then
                s_axis_counter_count <= s_axis_counter_count + '1';
            end if;
        end if;
    end process;
    data: process(clk)
    begin
            tmp <= s_axis_tdata;
            if(s_counter_count=0) then
                s_total_length_A <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=1) then
                s_total_length_B <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=2) then
                s_total_length_C <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=3) then
                s_total_length_D <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=4) then
                s_height_A <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=5) then
                s_height_B <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=6) then
                s_height_C <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=7) then
                s_height_D <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=8) then
                s_width_A <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=9) then
                s_width_B <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=10) then
                s_width_C <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=11) then
                s_width_D <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=12) then
                s_data_length_A <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=13) then
                s_data_length_B <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=14) then
                s_data_length_C <= tmp;--s_axis_tdata;
            end if;
            if(s_counter_count=15) then
                s_data_length_D <= tmp;--s_axis_tdata;
            end if;
        end if;
    end process;
    total_length <= s_total_length_D & s_total_length_C & s_total_length_B & s_total_length_A;
    height <= s_height_D & s_height_C & s_height_B & s_height_A;
    width <= s_width_D & s_width_C & s_width_B & s_width_A;
    data_length <= s_data_length;
    s_data_length <= s_data_length_D & s_data_length_C & s_data_length_B & s_data_length_A;
    data_tvalid <= '1' when (s_counter_count = 16 and s_axis_tvalid='1') else '0';
    data_tlast <= '1' when (s_counter_count = 16 and s_axis_counter_count=s_data_length-1) else '0';
    --data_tdata <= s_axis_tdata when ((s_counter_count = 16 and s_axis_tvalid='1') and data_tready='1') else (others=>'0');
    data_tdata <= tmp when ((s_counter_count = 16 and s_axis_tvalid='1') and data_tready='1') else (others=>'0');
    s_axis_tready <=  data_tready when s_counter_count=16 else '1';
end Behavioral;
Which turns out to work as expected:
The testbench works only if I uncomment the wait until s_axis_tready='1'
axisToIP:
library IEEE;
entity axisToIP is
    generic (
        BITS    : natural := 8
    Port (
        clk : in std_logic;
        rst : in std_logic;
        -- AXIS Slave
end axisToIP;
begin
                             '0';
                            else '0';
    begin
            end if;
            end if;
        end if;
    end process;
    data: process(clk)
    begin
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
            end if;
        end if;
    end process;
end Behavioral;
Testbench:
library IEEE;
entity axisToIP_tb is
end;
architecture bench of axisToIP_tb is
  component axisToIP
    generic (
        BITS    : natural := 8
      Port (
          clk : in std_logic;
          rst : in std_logic;
  end component;
  signal clk: std_logic;
  signal rst: std_logic;
  signal s_axis_tvalid: std_logic;
  signal s_axis_tdata: std_logic_vector (7 downto 0);
  signal s_axis_tlast: std_logic;
  signal s_axis_tready: std_logic;
  signal total_length: std_logic_vector (31 downto 0);
  signal height: std_logic_vector (31 downto 0);
  signal width: std_logic_vector (31 downto 0);
  signal data_length: std_logic_vector (31 downto 0);
  signal data_tdata: std_logic_vector (7 downto 0);
  signal data_tvalid: std_logic;
  signal data_tlast: std_logic;
  signal data_tready: std_logic;
  signal stream : std_logic_vector(223 downto 0) := x"1800000002000000020000000C000000111213212223313233414243";
begin
  -- Insert values for generic parameters !!
  uut: axisToIP generic map ( BYTES            =>  17,
                              BITS             => 8  )
                   port map ( clk           => clk,
                              rst           => rst,
                              s_axis_tvalid => s_axis_tvalid,
                              s_axis_tdata  => s_axis_tdata,
                              s_axis_tlast  => s_axis_tlast,
                              s_axis_tready => s_axis_tready,
                              total_length  => total_length,
                              height        => height,
                              width         => width,
                              data_length   => data_length,
                              data_tdata    => data_tdata,
                              data_tvalid   => data_tvalid,
                              data_tlast    => data_tlast,
                              data_tready   => data_tready );
  stimulus: process
  begin
    s_axis_tdata <= (others=>'0');
    s_axis_tvalid <= '0';
    s_axis_tlast <= '0';
    rst <= '0';
    rst <= '1';
    rst <= '0';
    data_tready <= '1';
    wait for 2*clock_period;
    s_axis_tvalid <= '1';
    --wait until s_axis_tready='1';
    while(s_counter_count<28) loop
        if s_axis_tready='1' then
            s_axis_tdata <= stream(223 downto 216);
            stream <= stream(215 downto 0) & "00000000";
            if(s_counter_count=28-1) then   -- TotalBytes - 1
                s_axis_tlast <= '1';
            else
            end if;
        end if;
    end loop;
    wait;
  end process;
  clocking: process
  begin
      clk <= '1', '0' after clock_period / 2;
    end loop;
    wait;
  end process;
end;
So at this point I could say that the intermediate IP between incomming AXI Stream and the HLS IP behaves as expected. Now, I incorporate it into a top module to combine it with the HLS IP:
library IEEE;
entity top_converters is
  port (
end top_converters;
architecture behavior of top_converters is
begin
--    axis_in: entity work.axis(behavior)
--      port map(
--        M_AXIS_0_tdata => s_in_tdata,
--        M_AXIS_0_tlast => s_in_tlast,
--        M_AXIS_0_tready => s_in_tready,
--        M_AXIS_0_tvalid => s_in_tvalid,
--        S_AXIS_0_tdata => S_AXIS_0_tdata,
--        S_AXIS_0_tlast => S_AXIS_0_tlast,
--        S_AXIS_0_tready => S_AXIS_0_tready,
--        S_AXIS_0_tvalid => S_AXIS_0_tvalid,
--        s_axis_aclk_0 => s_axis_aclk_0,
--        s_axis_aresetn_0 => s_axis_aresetn_0
    axisToIP_0: entity work.axisToIP(Behavioral)
        generic map(
              BYTES => 17,
              BITS => 8
        Port map (
              rst           => s_axis_aresetn_0,
              s_axis_tvalid => S_AXIS_0_tvalid,
              s_axis_tdata  => S_AXIS_0_tdata,
              s_axis_tlast  => S_AXIS_0_tlast,
              s_axis_tready => S_AXIS_0_tready,
              total_length  => open,
              height        => open,
              width         => open,
              data_length   => open,
              data_tdata    => s_in_tdata,
              data_tvalid   => s_in_tvalid,
              data_tlast    => s_in_tlast,
              data_tready   => s_in_tready
      port map(
        port map(
end behavior;
With its testbench:
library IEEE;
entity top_converters_tb is
end;
architecture bench of top_converters_tb is
  component top_converters
    port (
  end component;
begin
  uut: top_converters port map ( M_AXIS_0_tdata   => M_AXIS_0_tdata,
  stimulus: process
  begin
    wait until S_AXIS_0_tready='1';
            S_AXIS_0_tdata <= stream(223 downto 216);
            else
            end if;
        end if;
    end loop;
    wait;
  end process;
  clocking: process
  begin
    end loop;
    wait;
  end process;
end;
And the first block does not behave like previously when it was not connected to the HLS ip:
The first thing to notice is that the 2 counters that I have there, start counting correctly as expected but s_axis_tdata only starts streaming on the rising edge of s_axis_tready- Therefore, if t_axis_tready is already 1 and there are now triggers, how can this be simulated? In order to make it work, I commented also wait until S_AXIS_0_tready='1' and then it worked....
@calibrais the issue the testbench? If so, what is then?
Thanks for the help
