antonin_fpga
Simulating sub block ip, but not recognized on sources->Hierarchy view
i followed all the step in https://www.xilinx.com/support/answers/60703.html
But my sub block of design_1 that i want to simulate is still not on my hierarchy tree. It is but with the "?".
I did set Hierarchy Update to Automatic Update, Manual Compile Order.
I tried differents compile ordrering.
The parser can find a component in design_1.vhd and all the sub-components instantiated in it ?
I'm on VIVADO 2018.2.2
Thank you
antonin_fpga
Hi @shameera , thanks for your reply.
Actually sometimes i had no error and the simulation ran, but with nothing instantiated...
Now i fixed it, indeed i had the issue AR# 71710 https://www.xilinx.com/support/answers/71710.html
Antonin
shameera
Hi @antonin_fpga ,
Although it shows the module as missing in the hierarchy window, I think it should be able to run simulation without any errors. Can you please confirm if you are facing any errors while running simulation ?
antonin_fpga
Antonin
