cvasselin
Simulation Behavior fails with Vivado 218.3
Good Morning,
My Design has been achieved with Vivado 217.4; now I would like to be compliant with Vivado 218.3. I . Syntesis, Implementation and Bitstream have been correctly done with Vivado 218.3. Unfortunatly Simulation behavior fails. Below an extract of the project_1\project_1.sim\sim_1\behav\xsim\xvlog.log file :
INFO: [VRFC 10-2263] Analyzing Verilog file "C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.ip_user_files/bd/system/ip/system_pll_0_0/system_pll_0_0_clk_wiz.v" into library xil_defaultlib
INFO: [VRFC 10-311] analyzing module system_pll_0_0_clk_wiz
INFO: [VRFC 10-2263] Analyzing Verilog file "C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.ip_user_files/bd/system/ip/system_pll_0_0/system_pll_0_0.v" into library xil_defaultlib
INFO: [VRFC 10-2263] Analyzing Verilog file "C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.srcs/sources_1/bd/system/ipshared/ec67/hdl/axi_infrastructure_v1_1_vl_rfs.v" into library axi_infrastructure_v1_1_0
INFO: [VRFC 10-311] analyzing module axi_infrastructure_v1_1_0_axi2vector
INFO: [VRFC 10-311] analyzing module axi_infrastructure_v1_1_0_axic_srl_fifo
INFO: [VRFC 10-311] analyzing module axi_infrastructure_v1_1_0_vector2axi
INFO: [VRFC 10-2263] Analyzing SystemVerilog file "C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.srcs/sources_1/bd/system/ipshared/3b24/hdl/axi_protocol_checker_v2_0_vl_rfs.sv" into library axi_protocol_checker_v2_0_1
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_axi4litepc_asr_inline
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_axi4pc_asr_inline
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_core
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_syn_fifo
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_reporter
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_threadcam
ERROR: [VRFC 10-2989] 'sc_util_v1_0_2_pkg' is not declared [C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.srcs/sources_1/bd/system/ipshared/3b24/hdl/axi_protocol_checker_v2_0_vl_rfs.sv:5485]
ERROR: [VRFC 10-2865] module 'axi_protocol_checker_v2_0_1_threadcam' ignored due to previous errors [C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.srcs/sources_1/bd/system/ipshared/3b24/hdl/axi_protocol_checker_v2_0_vl_rfs.sv:5453]
INFO: [VRFC 10-311] analyzing module axi_protocol_checker_v2_0_1_top
ERROR: [VRFC 10-2865] module 'axi_protocol_checker_v2_0_1_top' ignored due to previous errors [C:/Users/crvass/Documents/red pitaya/projects/sdr_receiver_DDS/project_1/project_1.srcs/sources_1/bd/system/ipshared/3b24/hdl/axi_protocol_checker_v2_0_vl_rfs.sv:5858]
drjohnsmith
code says it can not find 'sc_util_v1_0_2_pkg'
check it exists in the folder , added to the project,
       try removing it fomr the project and re adding,
drjohnsmith
dpaul24
@cvasselin,
The problem is pointed out in the above post.
Because I suspect the SV unit is part of the test-bench.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
cvasselin
How to fix this ?
Best Regards,
drjohnsmith
