07-09-2013 09:48 AM
Has anyone seen an issue where the simulation display mismatches in a couple of ways? I'm running Vivado 2013.1, but have tried this in ISE 14.4 as well on a Windows 7 64 bit machine.
From the attached file, the frame cnt register shows 917503, but in the waveform itself it shows 917489. Also, in bit 6 of the frame cnt register, the position of the marker shows the bit to be 1 as a value, but in the waveform it is clearly 0. The waveform is correct, but the Value listing is showing odd behavior.
John
07-09-2013 10:01 AM
Check that you are associating the right curswor with the right value (I recall there are more than one cursor ro you can get difference measurements)....
08-03-2013 04:38 AM
