Simulation & Synthesis files of FIFO v13_2_3 for custom IP
We have our custom IP & want to use FIFO, so which files we need to add in file sets of synthesis & simulation from generated files of FIFO folder & which library needs to be specified for the compilation for this files.
Re: Simulation & Synthesis files of FIFO v13_2_3 for custom IP
HI @verilog_bee
In your custom IP design, you can add the FIFO IP from IP catalog and generate output products. This will generate the required synthesis and simulation files.  For more information on the files generated please refer the below guide page#201
https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v13_2/pg057-fifo-generator.pdf
If you are using supported third party simulator by Vivado then you can compile the simulation libraries using compile_simlib command. Please refer the below ug900 page#15:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug900-vivado-logic-simulation.pdf
Thanks & Regards,
Sravanthi B
HI @verilog_bee
Thanks & Regards,
Sravanthi B
