Observer rickardaf
Simulation error in Vivado 2013.4 [Simtcl 6-30]
I'm trying to run simulation but getting error:
ERROR: [Simtcl 6-30] Unable to locate simulation image at 'xsim.dir/tb_time_synth/xsimk.exe'
[Vivado 12-2332] Received fatal error while launching XSIM application!
I've tried
Run behavioral simulation
Run post-synthesis functional simulation
Run post-synthesis timing simulation
Run post-implementation functional simulation
Run post-implementation timing simulation
and they're all giving me the same error.
I'm running Windows 7 pro SP1 64 bit and using Vivado webpack 2013.4.
I've read other forum-threads but no success.
I've tried:
running Vivado in 32 bit mode => same error
recreating the project and add files and testbench => same error
running batch mode => same error
reinstalled Vivado => no difference
running simulation in TCL mode => same error
loading example project (Zynq system) and run simulation on it => same error
one thread mentions the program "dependency walker" so I tried it on xsim.exe in both win32.o and win64.o folder,
they gives the same result
LIBBOOST_FILESYSTEM.DLL     Error opening file. Can't find file (2)
LIBBOOST_PROGRAM_OPTIONS.DLL    Error opening file. Can't find file (2)
LIBBOOST_SIGNALS.DLL    Error opening file. Can't find file (2)
LIBRDI_COMMON.DLL    Error opening file. Can't find file (2)
LIBRDI_COMMONMAIN.DLL    Error opening file. Can't find file (2)
SHSMP.DLL    Error opening file. Can't find file (2)
STLPORT.5.2.DLL    Error opening file. Can't find file (2)
can somebody help me with this?
Re: Simulation error in Vivado 2013.4 [Simtcl 6-30]
i think it's the problem with the testbench code, especially when some signals in use is without any/correct defination, such as wire or reg signals...i came across with the same problem, though the thread won't report the missing defination as errors and go through, but later the information such as [Simtcl 6-30 ...] prompts out. i checked the test bench code accroding to the messages/log, and added the defination of some signals, then"Running xelab.." can start out to run.FYI.
What OS are you using?
Also this thread may help you: http://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2013-4-Simulation-Problem-in-Windows-8/td-p/397171
Observer rickardaf
I'm running Windows 7 pro SP1 64 bit.
I've previously tried most of the things in that thread but with no success.
I haven't tried re-adding top level testbench before but I tried it now and unfortunately didn't work.
I've checked and all the files I've created are present.
the attached file in the thread from roshansilwal contains the same errors as mine for win64.o/xsim.exe but I get the same errors for win32.0/xsim.exe
Is the issue project specific? Does the error occur if you try an example design?
Observer rickardaf
It isn't project specific
I've tried loading example project (named "Zynq system") and run simulation on it and I get the same error
Observer rickardaf
before anybody asks,
When I downloaded Vivado I calculated md5 checksum and confirmed that it was correct.
Observer rickardaf
Some update from my part that might help some support tech solving my problem.
I tried removing the testbench file and then put the wrapper as top for the simulation and then it works without error.
I tried it on both my project and the example project (in the example I removed "tb.v" and put "zynq_1_wrapper.vhd" as top) and none of them gives any error.
the only problem now is: how can I simulate signals without at testbench???
why do I get this error as soon as a testbench is present?
You can force signals without a testbench to your UUT.
Refer page 86:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug900-vivado-logic-simulation.pdf
Debraj
You can give a try by running simulation in command line mode and invoking the snapshot in GUI.
You can find the steps in UG900. link given in the previous post.
Observer rickardaf
First of all, I'm using VHDL so I don't use 'wire' or 'reg' but I understand what you mean.
I have no idea why this should work when errors should reportable as error (at least that's what I think). But I've gone through my testbench and fixed all the warnings (had no error) and now the simulation starts.
I didn't think that could be the problem when even the example project got the [Simtcl 6-30 ...] error. I looked through the example project's testbench and it has some warnings (no errors). When I solved them its testproject works as well.
Strange that the code works on hardware but not in simulation...
Thank you everybody for your help.
