Simulation opening multiple WCFG waveforms
   In my current project using Vivado 2017.4 and a Artix 7 device I have been working on simulations of some RTL which has been working great.   My only annoyance is that everytime I open my simulation it opens multiple WCFG files and I have to manually close the ones I do not want to have open.   If I manually edit the project.xpr file I can see indeed that multiple files are being associated.
   Is there a way to edit this in the Vivado GUI, or if I want only a single wcfg file do I have to manually edit the file (see below screenshot) and remove lines 311...315 and line 328 for example if I do not want to see the I2C_test_behav.wcfg?
Tim
Re: Simulation opening multiple WCFG waveforms
you can change it from Simulation Sources --> Waveform Configuration File
FPGA enthusiast!
All PMs will be ignored
FPGA enthusiast!
@Anonymous,
   Thanks, I wasn't aware of those files in the sources view.
Tim
Actually that GUI method is too blunt of an instrument.
If you have multiple simulation sets associated with a project, you'll want to specify the simulation set you're adding to by modifying the GUI - based command.
Running the command from the GUI as indicated above yeilds the TCL command
add_files -norecurse /path/to/whatever.wcfg
This adds the file to every fileset in the project, which probably isn't precise enough. At least it added that wcfg file to both simulation sets and the "Design source" set - not exactly what I wanted.
I amended the tcl command with the specific sim set:
add_files -fileset sim_1 -norecurse /path/to/whatever.wcfg
And that worked exactly as I hoped.
Amendment: if you have a new waveform config file, you can save it into that specific simulation fileset from the GUI, the above applies when you have a waveform config file that you want to bring back into the simulation set.
The tool through the UI executes these commands from the save button (if you choose to add the wcfg to the simulation set)
add_files -fileset sim_1 -norecurse /some/useful/wave_config.wcfg
set_property xsim.view /some/useful/wave_config.wcfg [get_filesets sim_1]
- Jerry
