cja@ike.no
Simulation with FIFO_DUALCLOCK_MACRO
I have instantiated the FIFO_DUALCLOCK_MACRO to my project, but when I open Vivado and try to simulate the module containing the FIFO I get a question-mark on the FIFO-submodule.
I have tried to add the source from the xilinx unimacro-directory, but the added source shows up as an additional module on the same level as my testbench...
What am I doing wrong?
Here is my instance:
 fifo : for i in 1 to 6 generate
    u1_ch1 : entity unimacro.FIFO_DUALCLOCK_MACRO
      generic map (
        DEVICE                  => "7SERIES",  -- Target Device: "VIRTEX5", "VIRTEX6", "7SERIES"
        ALMOST_FULL_OFFSET      => X"0100",  -- Sets almost full threshold
        ALMOST_EMPTY_OFFSET     => X"0100",  -- Sets the almost empty threshold
        DATA_WIDTH              => 36,  -- Valid values are 1-72 (37-72 only valid when FIFO_SIZE="36Kb")
        FIFO_SIZE               => "36Kb",   -- Target BRAM, "18Kb" or "36Kb"
        FIRST_WORD_FALL_THROUGH => false)  -- Sets the FIFO FWFT to TRUE or FALSE
      port map (
        ALMOSTEMPTY => open,
        ALMOSTFULL  => fifoAlmostFull(i),
        DO          => dataFromFifo(i),
        EMPTY       => fifoEmpty(i),
        FULL        => fifoFull(i),
        RDCOUNT     => unusedSignalButRequiredToGetTheModuleToCompile1,
        RDERR       => fifoReadErrorFlag(i),
        WRCOUNT     => unusedSignalButRequiredToGetTheModuleToCompile2,
        WRERR       => fifoWriteErrorFlag(i),
        DI          => dataToFifo(i),
        RDCLK       => clk,
        RDEN        => fifoReadEnable(i),
        RST         => reset,
        WRCLK       => sclk,
        WREN        => fifoWriteEnable(i));
  end generate fifo;
vemulad
Check this related thread http://forums.xilinx.com/t5/Simulation-and-Verification/bram-tdp-marco-missing-when-instantiated-in-Vivado/td-p/511083/highlight/true
Deepika.
Deepika.
