Simulator Refuses To Run
Ever since I installed Windows 10 fall update, the program been more unstable. I manage to create a project, but I cannot run simulator anymore. Whenever I run simulator, it gets stuck on executing simulate step, then my anti- virus program says it running a scan on Vivado, I abort the scan and then the program crashes.
thakurr
@herbert_david396
Windows 10 fall update is not officially tested with any Vivado tool.Hence it is not officially supported.You can get such indeterministic results using such unsupported updates.Check this AR if you are using 2017.3
https://www.xilinx.com/support/answers/69908.html
Rohit
Rohit
prathikm
Hi @herbert_david396,
Try the workaround from the above AR69908.
>>["then my anti- virus program says it running a scan on Vivado, I abort the scan and then the program crashes."] Disable the anti-virus and run the tool. If the workaround is not helpful, I am afraid you will have to remove the Falls Update for tool support.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
