Visitor vicente
Simulator crash using Vivado 2015.2
I have a similar issue as described in this forum post:
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2015-2-simulator-hang/td-p/747363
Every time a try to simulate a rather simple design, just the ZYNQ block, the AXI interconnect peripherals and a really simple custom VHDL peripheral (no AXI), if the simulation time is higher than 40ms (sometimes 20ms) the vivado simulator always crash.
I've also tried using the latest Vivado version (2016.4) as recommended in the reference post without any success, perhaps the simulation time before the crash is sometimes a bit higher, but completely unreliable.
Please, if anyone can illuminate with a possible cause for this behaviour of the vivado simulator would be much appreciated.
Vicente
Re: Simulator crash using Vivado 2015.2
i would recommend you to use vivado 2016.4
Thanks and Regards
Balkrishan
Hi @vicente,
Can you please share the design files.
Sunilkumar
