ldm.eth
Some files doesn't appear under Similation Sources, but they are set to be used in Simulation... How to fix?
Hi All,
How can I create another files set for simulations?
Some files, which are defined to be used in simulation set, doesn't appear under the simulation set... Why?
As you can see below, the xgs_top.v is set to be used also in Simulation, but it doesn't appear under Simulation Sources ... Why?
Thank you!
graces
Is is seen under the top level hierarchy in Design Sources, or is it in Non-Module files?
ldm.eth
All the files are under Design Sources (not under the Non-Module files section), all the files are set to be used in the simulation, but they are not appear under the Simulation sources section...
I remember I selected by mistake some wrong file to be a Top of the Simulation Sources... Since then all the RTL files just dismissed from theSimulation Sources... So, how to bring them there again?
ldm.eth
How can I remove ALL the simulation sources from my Project and then add them according to the Design Sources?
