Digitalio
Strange timing of the simulation run
When I execute a command to run simulation for 1 second, Vivado runs it for 10 seconds instead (by the time shown in the simulation timeline window). Any ideas why this may be happening?
PS v2019.2.1
graces
Indeed, it should be a tool issue. Thanks for reporting this. I'll file a CR to have it fixed.
graces
I haven't seen such issue before. Did you type "run 1s" command in Tcl after simulation is launched? Can you attach a test case to reproduce it?
fandrei
I used the toolbar button in the simulator GUI. Also, I found out that this problem doesn't happen in v2019.1.3, so apparently it's a new bug in 2019.2.1
It's happening in all the projects for me, no special test project is needed.
calibra
Voyager
Voyager
@graces
I confirm.
Just test:
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.numeric_std.all ;
entity lab6_tb is
end lab6_tb;
architecture arch of lab6_tb is
signal clk_tb : std_logic;
begin
clk_process: process
begin
    clk_tb <= '0';
    wait for 500 ns;
    clk_tb <= '1';
    wait for 500 ns;
end process;
end architecture ;
command "run 1 s" run for 10 second and "run 2 s"   run for 20 second.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
graces
