kathy1
Structural model- Memory design using D-Flipflop
In my project, I am designing a 8bit registers using D-Flipflop. During simulation when I give D=1, and CLK=1, I was able to get output. But when I give a continious Clock input as shown in below provided test bench ,I am not getting any output. Below provide is the verilog code for D-Flipflop,MUx and D-flipFlop test bench. Mux is used to provide a stable input to Flipfllop.
Please help, I couldnt find out where I didmistake
module D_flipflop(output Q2,input Data,CLK,S
wire Q2;
wire x0,a0,a1,a2;
wire xx0,aa0,aa1,aa2;
wire CLK_not;
wire x1,x2;
nand nand1 (a0,Data1,CLK);
nand nand2 (a1,x0,CLK);
nand nand3 (Q2,a0,a2);
nand nand4 (a2,a1,Q2);
Mux_2to1 MUX1(Data1,Data,Q2,S);
endmodule
module Mux_2to1(mux_out,input0,input1,S
input input0,input1,S;
output mux_out;
wire s_,x1,x2;
not (s_,S);
and and1(x1,s_,input0);
and and2(x2,S,input1);
or (mux_out,x1,x2);
endmodule
//// D-FLIPFLOP TEST BENCH/////
module D_Flipfloptest;
// Inputs
reg Data;
reg CLK;
reg S;
// Outputs
wire Q2;
// Instantiate the Unit Under Test (UUT)
D_flipflop uut (
.Q2(Q2),
.Data(Data),
.CLK(CLK),
.S(S)
initial begin
// Initialize Inputs
Data = 0;
CLK = 0;
S = 0;
#5 Data=1;
#5 forever CLK=~CLK;
#5 $display("%b",Q2);
end
endmodule
kathy1
I found out the error. I didntprovide propoer delay in testbench.
kathy1
gszakacs
Instructor
Instructor
I see at least two issues in the testbench:
initial begin
  Data = 0;
  CLK = 0;
  S = 0;
  #5 Data=1;
end
1) The red line means "wait 5 time units, then constantly toggle CLK with no time delay"
That's like an infinite clock frequency, and would preven the simulation from advancing in time.
I assume you meant something like:
forever #5 CLK = ~CLK;
This means "constantly wait 5 time units then toggle CLK" which would give a clock period of 10 time units with the first edge occurring after 5 time units.
2) The green line is after the forever loop.  It will never get executed.
-- Gabor
kathy1
Hi Gabor,
Thanks and you were right.
As i mentioned I am trying to create an "8 bit register file using structural model"module. When I tested my register file sepreatly, it is working fine. However, when I call this file in main program it give incorrect result, even if the input given is correct. What may be the issue?
thanks
kathy
