Visitor xsilverx
Sub-module simulation in Vivado
Hi! I tried to simulate a sub-module from my project's bd in Vivado 2018.4. I followed these instructions
https://www.xilinx.com/support/answers/60703.html
But instantiation didn't work.sim_submodule_1.pngFailed instantiation
What should I try to make instantiation correct in TB?
Could it be caused by my simulation sources list?ss_mine.pngSimulation sources for sub-module tb
ss_top.pngSimulation sources for top-level tb
回复: Sub-module simulation in Vivado
Did you switch to manual compile order as suggested in the AR?
Visitor xsilverx
I have tried to set it but:
1. When I set manual compile order for simulation there is message: Module references are out-of-date. Refresh Changed Modules. And if I choose Refresh... It causes a lot of errors.
2. When I run simulation there were a lot of errors in the other TBs (they are ok before it). Simulation did not run.
Finally I start it:
1. I don't Refresh Changed Modules.
2. I delete all other TBs from project.
Is it a correct actions or I should try to avoid it?
As I see it, if you set the sub-module testbench to top, it shouldn't affect other TB hierarchies.
Would you please provide the project archive so that I can try at my end?
