Voyager
Voyager
Test Bench Waveform Editor
ISE 9.2, Is there a way to copy and paste signal in existing waveform?
So far I had to work with the generated HDL code directly.
thanks,
Message Edited by legendbb on 02-27-2009 03:48 PM
Re: Test Bench Waveform Editor
Can you elaborate on what you mean by "Copy and Paste" into "existing waveform"?  The Testbench Waveform Editor will only add signals as found in the hierarchy viewer.  Which simulation objects do you want to copy and paste from?
Eddie
Voyager
Voyager
Thank you for your reply,
the "Copy and Paste" idea was actually came from Quartus II's wave form editor, where you can select a portion of signal changed made and copy paste to different time location.
The testbench waveform editor does not have this feature.  We apologize for the inconvenience.
Be advised, the Testbench Waveform Editor has been depracated starting the upcoming version of ISE.  As a replacement, you can use the "Language Templates" in the Edit menu, as well as the templates created for you when using "Add New Source" --> "VHDL testbench" / "Verilog test fixture" to write HDL testbench files.
Eddie
