li_zicong
Third party Simulators for specific Vivado
where can I find specifications about third party simulator compatible with Vivado?
Thanks!
graces
This is documented in UG973 of each Vivado release.
Alternatively, you can refer to the following AR on this topic.
https://www.xilinx.com/support/answers/68324.html
graces
vuppala
Hi @li_zicong
In UG973, https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf
Vinay
li_zicong
Thank you very much!
