Timing Simulation
How can I set 'sdftyp' as the sdf delay argument using GUI during timing simulation in Vivado 2019.2?
Hi @Ahalya ,
You can use the below property to set the sdf delay type or you can set it from simulation settings as shown below:
set_property -name {xsim.elaborate.sdf_delay} -value {sdfmax} -objects [get_filesets sim_1]
Thanks & Regards,
Sravanthi B
This will set the sdfdelay to sdfmax. I want it to be sdftyp.
@Ahalya ,
She already told you how to do it, it is just that she made a typo! Just type sdftyp in the box.
Because the .sdf_delay can take only 3 arguments -- -sdfmin|-sdftyp|-sdfmax
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
I cannot type arguments there. It is fixed to only 2 values. (sdfmin and sdfmax). Does that mean sdftyp is not allowed? Or is there any other method?
Guide
Guide
It is very possible that you cannot do sdftyp simulations. We know the Xilinx libraries are characterized for max and min, but there is no other place in the tools where there is any indication that a characterization at typ exists. Specifically, we know that static timing analysis can only be done at max and min.
That being said, why do you care? What value is there in doing a simulation at sdftyp?
Avrum
