jmcano
Timing simulation not enabled
I am using Vivado 2013.1 with a Kintex 7 KC705 Evaluation Board. I have just includes a CORDIC v.6 in my design to make a translation. I works fine in RTL design, synthesis, behavioral simulation and post-synthesis functional simulation.
However, the option to perform a post-synthesis timing simulation does not appear active in Vivado. Perhaps I have missed some step. Can  you help me?
Thanks in advance.
Jose M. Cano
jmcano@uniovi.es
jmcano
Solved. It had nothing to do with adding the IP CORDIC block. It was just that I had changed the target language options from Verilog to VHDL, and post-synthesis timing simulation was then not permitted.
Excuse me for any inconvenience.
jmcano
jmcano
jmcano
