Top Module vs Component; Who has priority over generics?
Hello.
I have a simple test design which uses a integer to select an output.
My top module code is like below
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity top_module is
    Port ( output : out std_logic_vector(9 downto 0)
end top_module;
architecture Behavioral of collision is
    component select_comp is
        generic(selection: integer);
        port(output: out std_logic_vector(9 downto 0));
    end component;
begin
    cmponent1: select_comp
        generic map(selection => 9)
        port map(output => output);
end Behavioral;
And my component code is like below
library IEEE;
entity select_comp is
    generic (selection : integer := 5 );
    Port ( output : out std_logic_vector(9 downto 0) );
end select_comp;
architecture Behavioral of select_comp is
begin
process
    begin
        case selection is
            when 0 => output <= "0000000000";
            when 1 => output <= "0000000001";
            when 2 => output <= "0000000010";
            when 3 => output <= "0000000011";
            when 4 => output <= "0000000100";
            when 5 => output <= "0000000101";
            when 6 => output <= "0000000110";
            when 7 => output <= "0000000111";
            when 8 => output <= "0000001000";
            when 9 => output <= "0000001001";
            when others => output <= "0000000000";
        end case;
        wait;
end process;
end Behavioral;
In my component code, generic 'selection' is initialized to 5. But in my top_module code, value 9 is passed to the selection.
After simulation, the output was "0000001001"(9) so I could guess that the value which was initialized inside the component(5) is ignored or overwritten.
Is is correct?
Thanks for your help.
Scholar dpaul24
Re: Top Module vs Component; Who has priority over generics?
@kimjaewon,
Is is correct?
Yes this is correct! Generic always takes precedence.
Please read a good VHDL tutorial.
FPGA enthusiast!
All PMs will be ignored
Scholar dpaul24
@kimjaewon,
Is is correct?
FPGA enthusiast!
So do you mean that the generic value at the top module(9) precedence over the generic value at the component(5) in my case?
Scholar richardhead
@kimjaewon
The component has no default value assigned. This means you technically have a missmatch.
The value assigned in the entity is just a default if no value is assigned when instantiating the entity.
Btw - components are not needed - they add extra burden to your code and increase compile times. It requires you to maintain 2 copies of essentially the same thing, and the compiler wont know if theres a missmatch until it gets to the mapping stage, which can be after several minutes for large designs. Using direct instatiation will cause a syntax error on a missmatch, which occurs very quick. If the source code is in VHDL, then you can use direct instantiation:
sel_inst : entity work.select_comp
generic map (...)
port map ( ... );
