Visitor kenchindino
Trouble running Xcelium
I have received the following instructions on how to run Xcelium:
  • compile simulation libraries using '-simulator xcelium'
  • point to the Xcelium compiled libraries
  • for integrated flow, Run Simulation
  • for export simulation flow, File-> Export Export Simulation  Select Xcelium (for script generation)
The following message is copied from Tcl Console:
compile_simlib -simulator xcelium -simulator_exec_path {/opt/cadence/installs/XCELIUM1710/tools.lnx86/bin/64bit} -family virtexuplus -language verilog -library unisim -dir {/home/user/ASIC/syn} -force
WARNING: [Vivado 12-5377] Language specific library compilation for IPs is not supported. By default, the libraries will be compiled for all languages.
INFO: [Vivado 12-4753] Extracting data from the IP repository...(this may take a while, please wait)...
* COMPILATION SUMMARY *
* Simulator used: xcelium *
* Compiled on: Fri Jan 26 10:29:51 2018 *
* Library | Language | Mapped Library Name | Error(s) | Warning(s) *
* secureip | verilog | secureip | 0 | 619 *
* unisim | vhdl | unisim | 3 | 1836 *
* unimacro | vhdl | unimacro | 1 | 612 *
* unifast | vhdl | unifast | 1 | 610 *
* unisim | verilog | unisims_ver | 0 | 1213 *
ERROR: [Vivado 12-5602] compile_simlib failed to compile for xcelium with error in 177 libraries (cxl_error.log)
compile_simlib: Time (s): cpu = 00:03:26 ; elapsed = 00:04:27 . Memory (MB): peak = 9425.207 ; gain = 0.000 ; free physical = 29551 ; free virtual = 109268
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
launch_simulation
INFO: [Vivado 12-5698] Checking validity of IPs in the design for the 'XSim' simulator...
INFO: [Vivado 12-5682] Launching behavioral simulation in '/home/kenchin/ASIC/syn/scu/scu/scu.sim/sim_1/behav/xsim'
INFO: [Vivado 12-4795] Using compiled simulation libraries for IPs
INFO: [SIM-utils-51] Simulation object is 'sim_1'
INFO: [USF-XSim-7] Finding pre-compiled libraries...
It seems most errors are related to VHDL but we are not using VHDL.
I don't know how to "point to the Xcelium compiled libraries", so I didn't do it and went ahead with "for integrated flow, Run Simulation" but Xsim is still being used.
Your help is appreciated.
Visitor kenchindino
Re: Trouble running Xcelium
Hi Aidan,
Thank you very much for the help. I finally got it to work by setting the parameter before I open the project.
Best Regards,
Ken
Hi @kenchindino,
Do you have the path to the Xcelium Simulator set in the tools when you try and compile the simulation libraries?
You need to have set where you want the libraries to be compiled to and where Xcelium is installed on your system.
The compiled library location is where you want to store the files that are compiled, you will also need to point to this location when you are running the simulation
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Visitor kenchindino
Hi Aidan,
The following is what I used to compile the libraries:
{/home/user/ASIC/syn} is where I wanted to put my libraries.
The problem is that on the Settings menu, I don't have the the option to select Xcelium.
Best Regards.
Visitor kenchindino
When I clicked "3rd Party Simulators" on the Settings menu, I could see Xcelium. So there must be something I am still missing.
Hi @kenchindino,
You  need to set the switch prior to opening your project.
If you set it in an already open project the Xcelium option may not show up, so open a new instance of Vivado, set the switch and check if the option is there. Then you canopen your project.
From your previous notes it looks like you are using Linux
I have checked the switch in 2017.3 on both Linux and Windows and the option was there.
In Windows, compilation of the libraries is not supported, e.g.
ERROR: [Vivado 12-3730] Invalid simulator 'xcelium' specified! Library compilation for this simulator is not supported on this platform.
It is present in Linux
Let em know if I can help further.
Best Regards
Aidan
Visitor kenchindino
Hi Aidan,
Best Regards,
Ken
