Trouble with ModelSim 10 and Xilinx libraries
I am trying to run a simulation using ModelSim, but when I run startsim.do, I get these messages
Loading work.local_max_tb(fast)
# Loading work.fifo_1kx32(fast)
# Loading unisims_ver.FDC(fast)
# Loading unisims_ver.FDP(fast)
# Loading unisims_ver.FIFO36E1(fast)
# Loading work.sep_buf_x(fast)
# Loading unisims_ver.FIFO18E1(fast)
# Loading unisims_ver.FIFO36E1(fast__1)
# Loading work.glbl(fast)
and  when I add the waves I do not see most of my signals
I then tried adding the -novopt flag, but I get an error
Failed to open lock file "/home/software/xilinx-13.2/ISE_DS/ISE/verilog/mti_se/10.0c/lin64/unisims_ver/_lock" in create mode.
# Permission denied. (errno = EACCES)
Below is my startsim.do file
# Create work library
vlib work
# Compile sources
vlog  "../hdl/reg_ff.v"
vlog  "../hdl/fifo_512x72.v"
vlog  "../hdl/fifo_512x32.v"
vlog  "../hdl/fifo_4kx32.v"
vlog  "../hdl/fifo_2kx32.v"
vlog  "../hdl/fifo_1kx32.v"
vlog  "lm_tb_new.v"
vlog  "$env(XILINX)/verilog/src/glbl.v"
# Call vsim to invoke simulator
vsim -novopt -L work -L secureip -L unisims_ver -L xilinxcorelib_ver work.local_max_tb glbl
# Add signals
do wave.do
# Run simulation
run -all
My modelsim.ini points to 13.2 xilinx libraries at
Not really sure if there is an installation issue or something to do with my scripts. Any help will be appreciated.
Sid
1) Check the directory permissions for the compiled library directory.
2) Try simulating any other example design and check if it works in Modelsim
3) Check that the compiled libraries versions is same as the ISE tool version.
Let me know the update after trying these steps.
Anirudh
Anirudh
I'm having the same problem, the above solutions do not work for me. Any other ideas what the cause could be?
