UNKNOWN VALUE
every time i try simulate something it comes to this.
I have attached files simulation and VHDL code.
@ilia-hadzhiev,
something basic.....
have you added the instiantiated modules in to the Vivado project?
FPGA enthusiast!
Consider giving Kudos if you like my answer.Accept as solution if my answer solved your problem.
VHDL knows nothing about types unless you include the library for that type, your test bench uses std logic vector , but no library included
Can I suggest a good book, ( I have no connection with these people )
http://freerangefactory.org/pdf/df344hdh4h8kjfh3500ft2/free_range_vhdl.pdf
And these guys are the real experts
https://www.doulos.com/knowhow/vhdl_designers_guide/test_benches_part_1/
i have forgot to copy those lines with the libraries,
they are there this is not the problem.
to #dpaul24 i have added the component instantiation if you are talking about that.
i decide to upload the Vivado project so you can see if you can find the problem.
If you could post your real code as an attachment then please,
saves us guessing,,
Done i have attached the Vivado project
You have not added your test bench to vivado,
http://users.wpi.edu/~rjduck/Vivado%20Simple%20VHDL%20Test%20Bench.pdf
Also suggest you follow the normal convention,
if your test bench is testing a file called adder.vhd
   then the test bench would be called adder_tb.vhd
The entity would be called adder also
