ilia-hadzhiev
UNKNOWN VALUE
every time i try simulate something it comes to this.
I have attached files simulation and VHDL code.
dpaul24
@ilia-hadzhiev,
something basic.....
have you added the instiantiated modules in to the Vivado project?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
drjohnsmith
VHDL knows nothing about types unless you include the library for that type, your test bench uses std logic vector , but no library included
Can I suggest a good book, ( I have no connection with these people )
http://freerangefactory.org/pdf/df344hdh4h8kjfh3500ft2/free_range_vhdl.pdf
And these guys are the real experts
https://www.doulos.com/knowhow/vhdl_designers_guide/test_benches_part_1/
ilia-hadzhiev
i have forgot to copy those lines with the libraries,
they are there this is not the problem.
ilia-hadzhiev
to #dpaul24 i have added the component instantiation if you are talking about that.
i decide to upload the Vivado project so you can see if you can find the problem.
drjohnsmith
If you could post your real code as an attachment then please,
saves us guessing,,
ilia-hadzhiev
Done i have attached the Vivado project
drjohnsmith
You have not added your test bench to vivado,
drjohnsmith
http://users.wpi.edu/~rjduck/Vivado%20Simple%20VHDL%20Test%20Bench.pdf
drjohnsmith
Also suggest you follow the normal convention,
if your test bench is testing a file called adder.vhd
   then the test bench would be called adder_tb.vhd
The entity would be called adder also
