[USF-XSim-62] 'elaborate' step failed with error(s) while executing '/home/......................._design.sim/sim_1/behav/xsim/elaborate.sh'
Hi all,
I am using Vivado 2019 tool, when i try to simulate my code, i am getting following error.
[USF-XSim-62] 'elaborate' step failed with error(s) while executing '/home/ssaraswathy/Documents/............/Uplane_8Layer_design.sim/sim_1/behav/xsim/elaborate.sh' script. Please check that the file has the correct 'read/write/execute' permissions and the Tcl console output for any other possible errors or warnings.
Choosen small path only , and I deleted the entire design and created the same design for many times. I dont know how to fix this issue.
hi @thaus_015,
Could you please share the design ???
Sunilkumar
Did you take a look at elaborate.log within the problematic path?
See if there're any specific errors, e.g. syntax error when compiling the source files.
