UVM testbench
Trying to run a UVM testbench using vivado and VCS simulator.
"UVM_HOME" is set to "/usr/synopsys/vcs-mx/M-2017.03-SP1/etc/uvm-1.2/".
After export_simulation command, we use the following:
vlogan_opts="-full64 -kdb -lca -timescale=1ns/1ps +incdir+/usr/synopsys/vcs-mx/M-2017.03-SP1//etc/uvm-1.2//src /usr/synopsys/vcs-mx/M-2017.03-SP1//etc/uvm-1.2//src/uvm.sv /usr/synopsys/vcs-mx/M-2017.03-SP1//etc/uvm-1.2//src/dpi/uvm_dpi.cc -ntb_opts uvm"
vhdlan_opts="-full64"
vcs_elab_opts="-full64 -t ps -licqueue -l elaborate.log -debug_access+all"
vcs_sim_opts="-ucli -licqueue -l simulate.log +ntb_random_seed_automatic "
We get the following error at run time:
Error-[DPI-DIFNF] DPI import function not found
/usr/synopsys/vcs-mx/M-2017.03-SP1//etc/uvm-1.2//src/base/uvm_resource.svh, 386
  The definition of DPI import function/task 'uvm_glob_to_re' does not exist.
  Please check the stated DPI import function/task is defined, and its
  definition is either passed in a source file at compile-time, or provided in
  a shared library specified using the LRM Annex-J options at run-time.
And get the following error:
When we duplicate the "+incdir..." both to the vlogan and the elaborate phase, we get a compilation error:
Error-[SE] Syntax error
  Following verilog source has syntax error :
  "/usr/synopsys/vcs-mx/M-2017.03-SP1//etc/uvm/uvm_pkg.sv", 31: token is ';'
  package uvm_pkg;
When using the following command for using VCS (without vivado), then the testbech runs OK.
 vcs  -full64 '-timescale=1ns/1ns' '-sverilog' +incdir+$UVM_HOME/src $UVM_HOME/src/uvm.sv $UVM_HOME/src/dpi/uvm_dpi.cc   design.sv testbench.sv  '+UVM_TESTNAME=mem_wr_rd_test'    -R
Is it possible to have a UVM env and run it using vivado and VCS simulator? What are the necessary compilation directives?
Thanks!
Hi all,
Thanks very much for the links and tips, when we substitute the compiler directives in the output script of "export_simulation" with the following directives, then UVM is loaded (also allows to use Verdi as GUI):
vlogan_opts="-full64 -kdb -lca -timescale=1ns/1ps +incdir+$UVM_HOME/src $UVM_HOME/src/uvm.sv $UVM_HOME/src/dpi/uvm_dpi.cc +incdir+$UVM_HOME/vcs $UVM_HOME/vcs/uvm_custom_install_vcs_recorder.sv +incdir+$UVM_HOME/verdi $UVM_HOME/verdi/uvm_custom_install_verdi_recorder.sv -CFLAGS -DVCS -ntb_opts uvm"
vcs_elab_opts="-full64 -t ps -licqueue -l elaborate.log -debug_access+all -ntb_opts uvm"
vcs_sim_opts="-ucli -licqueue -l simulate.log +UVM_TESTNAME=test_a +ntb_random_seed_automatic"
Hopefully it may help someone else..
Is there any way passing these directives as arguments to the "export_simulation" command?
Or maybe compiling the UVM included dirs to a lib, and then load it to the run as "uvm_lib" instead of compiling them for each run?
Thanks again :)
Hi @avigailr,
I found the following example of running a UVM testbench with Vivado and VCS Simulator which may be useful
https://forums.xilinx.com/t5/Simulation-and-Verification/System-verilog-UVM-simulation-for-Xilinx-EMAC/td-p/274612
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
@avigailr,
It is very much possible that UVM runs without any problems in VCS but fails with Vivado.
Because UVM might not yet be supported on Vivado simulator. Let a Xilinx personnel confirm this.
btw - Have you tried out the Batch/Script mode in Vivado Simulator, pp 122 on https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug900-vivado-logic-simulation.pdf
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Hi all,
Thanks again :)
